K&T Milwaukee 2HL Vertical Swivel Head Milli
Watty
Jun 4, 2016
Trying to get my old girl squared away. Looking for advice on fluids way oil etc. I have a 150 way oil in hand but am in need fluids to fill the additional reservoirs. Any help will be appreciated.
Knee and column on their other mills use Mobil DTE Heavy Medium. If table/saddle is provided with a one shot Bijur pump like my CH, I put Vactra Numbered way oil in there
Manual scan - thanks to member Ramsay1
Kearney & Trecker Co. - Publication Reprints - Kearney and Trecker Operator Manual 1h-2hl | VintageMachinery.org
Parts Book scan - thanks to member Ramsay1
Kearney & Trecker Co. - Publication Reprints - Kearney & Trecker 1H-2HL Parts | VintageMachinery.org
1940 Lube Bulletin
Kearney & Trecker Co. - Publication Reprints - Kearney & Trecker Lubrication Bulletin 32-B | VintageMachinery.org
Thanks Ramsey, I think I understand the column and Knee but the manual call for Grease in the Head Zerks? Sovarex #1 Do you know a good equivalent?
Sovarex I think was a trade name of Socony Vacuum later Mobil Oil Corp...I have used Exxon #2 grease In my vertical head attachments with no problems...Number 1 is not as thick as #2.. You could try your local oil supplier maybe they can cross it over.. Just don't overgrease as at higher speeds, grease will churn and cause a temperature rise..Ramsay 1:)
