Local boiler explosion - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
  1. #21
    Jun 2001
    St Louis
    16,474
    1322
    2449
    Also, doesn't the city/state have a boiler inspection process funded by the taxpayers ?
    Someone isn't doing their job eh ?
    NO....
    City does NOT inspect boilers. They just require a licensed operator on duty whenever it is in use, presumably expecting that person can shut down the boiler and perform an inspection when needed.
    Fat chance, that guy is told what to do and when. He won't be allowed to shut off jack.
    I would assume the insurance people require 3rd party inspection of boilers. But no idea if this one was ever inspected.
  2. Likes digger doug liked this post
  3. #22
    Nov 2011
    Missouri, USA
    2,782
    1354
    2710
    Plus, imagining that part of town, I'm betting negligence is quite likely. Whether it's on the part of a 3rd party inspector, or the people working there. Very unfortunate.
  4. #23
    Aug 2013
    749
    439
    203
    In California, as a former pressure vessel manufacturer (not user), we could have the state Department of Industrial Relations come out for inspection, or hire the Hartford or other insurance inspectors. We always used the State. They were knowledgeable and good at their job (amazing for Cal GOV!).
    At the new job, the plant super says no one has ever looked at the air receivers on our compressors, not the state, city, fire or insurance. He said they last about 3 years before the heads are gone and we evidently then buy new. Glad retirement is upon me, and I don't have to worry about a 1000 gallon air receiver exploding on the other side of the building from me...
  5. #24
    Jun 2001
    St Louis
    16,474
    1322
    2449
    More recent news stories suggest that the boiler in question may not have been inspected for many years.
    The State requires inspections, but the City of St Louis is exempted from that requirement. And the city does not require inspections, just the licensed operator, apparently relying on the operator to make the call for inspection, or to shut down in case of unsafe operation. But the licensed operator has a boss........ who is not typically fond of shutdowns, or anything expensive.
    So, unless an insurance company required the inspection as a condition of insurance, AND knew there was a boiler, it seems as if it may have been many years since inspection. If the company self-insures, it seems highly unlikely that any inspections by 3rd parties have ever been done, based on typical business behavior in low-margin industries.
    And if the insurance folks (assuming there were insurance policies) did NOT know there was a boiler, it's possible they may decline to cover the results of the accident.
  6. #25
    Jun 2001
    St Louis
    16,474
    1322
    2449
    There was a pic of the thing being pulled out of the building it landed on in the paper today. One end obviously blew out, and sent it out like a rocket.
    They also said it was not actually a boiler, they called it a "Semi closed reciever"
    Tank that exploded and killed four people is removed from St. Louis laundry company roof | Metro | stltoday.com
  7. Likes Greg Johnson liked this post
  8. #26
    Feb 2004
    peekskill, NY
    23,627
    3773
    Quote Originally Posted by JST View Post
    From the photo it seems very similar to an incident years ago in NYC.
    There was a processing lab on an upper floor in a tall building, which relied on water pumped up from tanks in the
    basement. Plumbers had partly finished an installation for new pumps, but had not tied in the pressure switches.
    In the morning the folks in the lab upstairs closed the switch that started the pumps, which overpressured the system.
    One of the vertical, cylindrical tanks had the dished head on the bottom snap through, and fail. It then performed the
    classic water/air rocket thing as the water in the bottom shot out through the failed head.
    Because this was in the concrete basement, there would have been no harm - except the specific tank that failed, was
    directly under a gas main that ran along the ceiling. And there was a poorly made-up fitting (found later in the wreckage)
    that came loose.
    Gas filled the basement area, and was distributed through the building via the elevator shafts, where incoming workers
    were cycling the elevators to get to their offices on upper floors. Until there was an ignition source.
    All from the amazing book "Why Buildings Fall Down" by Levy and Salvadori.
    Why Buildings Fall Down: How Structures Fail: Matthys Levy, Mario Salvadori, Kevin Woest: 978393311525: Amazon.com: Books
  9. Likes SouthBendModel34, Mike C. liked this post
  10. #27
    Jun 2001
    St Louis
    16,474
    1322
    2449
    Preliminary report is out.
    Repairs were done, and more recommended years ago, but not done. Bottom shell was down from 1/4 inch to 80 thou.
    Repairs were recently scheduled, and the system shut down pending repair. For reasons "nobody can figure out", it was fired up again, and failed as it was coming up to pressure.
    A fair bet at least one person knows EXACTLY why it was started, and is keeping quiet..... something like "we are losing money every day, while we wait... Get that thing running or you are fired!".
    And the operator WAS fired.... or more likely, boiled.
    Corroded steel caused 'catastrophic failure' leading to tank explosion that killed 4 near Soulard | Metro | stltoday.com
  11. Likes t.jones liked this post
  12. #28
    Feb 2004
    peekskill, NY
    23,627
    3773
    This is one of those cases where at least one manager for that company, and possibly the CEO, needs to be led off in handcuffs.
  13. Likes JNieman, JST, tdmidget liked this post
  14. #29
    Jun 2001
    St Louis
    16,474
    1322
    2449
    Very much so......
    But, it is also possible that the place is so lax that the boiler was not tagged as out of service, and the operator just did his normal job. We do not know.
    We can suspect as much as we like, but proof is needed for arrest and prosecution.
    I'd think a tag-as-out-of-service failure would be an OSHA issue, at the very least. Dunno if it rises to the level of arrests and prodecution.
    Looks like there are grounds for alleging negligence, from the report as quoted in the paper.
    I say "boiler" and so did the paper, but apparently it was actually a condensed water receiver, a sort of pressurized hotwell, it seems. Part of the boiler system, but not the actual "fired vessel".
  15. Likes SouthBendModel34 liked this post
  16. #30
    Feb 2004
    peekskill, NY
    23,627
    3773
    "We can suspect as much as we like, but proof is needed for arrest and prosecution. "
    Actual evidence proving the case beyond doubt is needed for *conviction*. There's probable cause that a crime happened
    here. Police arrest folks all the time on suspicion. This would be a good time to do that now.
    Start with the CEO of the company. Have press on hand.
  17. #31
    Mar 2007
    On Elk Mountain, West Virginia, USA
    1,901
    691
    629
    This story is a good illustration of the dilemma of engineers and repair contractors. I was asked by a good long-time customer a few months ago to repair his broken log-truck frame. I went to look at it and he said, "I have the piece all cut and all the holes drilled, you just please weld it in". But in my "professional" opinion, the piece he provided did not adequately overlap the stress concentration that led to the original failure, the fuel tank and several other brackets and at least one cross-member would have to come off and a longer piece of steel made to allow proper repair.....I explained this, and we politely argued for a while. I said in the end that it was his truck and what he suggested might work, but I would not be the one to do it that way.
    I heard last week that he fixed it his way, and it's back on the road hauling 30 tons of logs every day. God bless us all.
  18. Likes Paolo_MD liked this post
  19. #32
    Aug 2005
    Tucson AZ
    5,834
    7712
    2650
    Quote Originally Posted by magneticanomaly View Post
    Every day until the day it breaks. Then we have to hear " it couldn't be the repair. It hauled 30 tons every day"
  20. #33
    Jun 2001
    St Louis
    16,474
    1322
    2449
    Quote Originally Posted by jim rozen View Post
    The DA does not like to be "handed a pup" like that, they want a "case" usually.
    We'll see. I still am of the totally unsupported opinion that there was probably a management demand.... Kinda like with the big oil spill in the Gulf... for that I seem to recall a manager said to keep going or else.
  21. #34
    May 2013
    RVA
    Quote Originally Posted by lathefan View Post
    ...watch the center of the roof...water heater launches at the 12 second mark...lands at 28 seconds...
    50 Gallon water heater explosion - YouTube
    For those that don't quite remember their high school physics classes, 16 seconds in the air means it reached a height of just over a thousand feet.
  22. Likes Locodad, JNieman liked this post
  23. #35
    Jun 2007
    Mass
    380
    24
    32
    I was actually in St. Louis when this happened - it was crazy as the details came out.
  24. #36
    Jun 2001
    St Louis
    16,474
    1322
    2449
    Quote Originally Posted by cuog View Post
    The quoted numbers were a shorter flight, and a lower altitude, but it did quite enough damage either way.
