handsome devil
Hot Rolled
- May 4, 2005
- Bonduel, Wi
This is somewhat of a continuation of my radial drill project.
http://www.practicalmachinist.com/v...uestions-342771/?highlight=radial+drill+press
But is only a lube question. I have gone on Drive alls home page and did not find an anwwer that made sense. Also searched past threads and found some interesting info about not using some newer synthetic gear lubes. My drill press went through a flood and motor and gear box were both underwater for a couple of weeks. Motor is fine now. Pulled the cover off to inspect gear box and all appears to be fine. The original owner had drained it after the flood. Some ice in the bottom but all below the gears and a small amount of original oil. Cleaned it out pretty good and every thing appears fine. So the million dollar question is what kind of gear lube to I put in. Would guess it was about 80 wt that I finished removing. Even heating it up did not make it run any faster. So would a 80 wt non detergent type oil be ok to use? And how do you know how far to fill it up? There is a add plug on top and a drain plug on bottom. No overfill plug like on some machines or any kind of dip stick to check level. Is this tranny some sort of "total immersion" it would appear to me that it would be some sort of splash lube system. Any thought on what and how to proceed? Regards, John.
