Sheraton2,
Removing spindle - seems like you are on the right track now. Just a kind reminder: when pulling the spindle, take your time and note position of all gears, collars and ev. shims as they come off.
Wonder why your spindle bearings are worn - could they have been adjusted too tight? Were there signs of rough handling - hammer and mandrel instead of hooked spanners? Or was it simply due to metal chips in the oil? I put a magnet in the drain plug on my own late hoping it will collect at least some of the miniflakes.
Pls keep posting picures.
Lars
Sheraton2,
I don't remember having any problems backing off retaining collars - the Hendey manuals do not make any distinction between 12 or 18 speeds. You will not be able to back off the collars completely, there is not space enough. Instead you undo them bit by bit as you pull out the spindle. You have to move the sliding clutch as far as possible to the left with the dogs engaged. You should then be able to slide big gear to the left, again creating as much space as possible by engaging the dogs. The helical gear is not the problem. The big gear should slide freely when collar loosened. If you think the helical gear is the problem, then try to spin the intermediate shaft or find a neutral with gear shift levers (between the positioning slots.)
I think you will figure it out.
Lars
Notice
