JZC
- May 20, 2009
- Vermont USA
This is a bit off-topic, but does anyone collect documents / records of air compressor companies?
I'm curious to learn the corporate history, and eventual fate of a company named "Mills" that made air compressors, and possibly other industrial equipment.
I don't know much more than the name, and they at least made a very nice two cylinder unit with the name cast into she side of the crankcase.
I've had one up in the rafters of my shop for decades where it has done yeoman service until recently when the paper gasket between the valve plate and cylinders blew ( the cylinders are 180 degrees out of phase ) and I finally had to take it apart.
It has a stroke of about 3 inches and bore of maybe a bit less than 2, on each cylinder.
I've been curious about this beast since I got it, and when the web finally came along in the early 90's I occasionally did some half hearted research, but never found anything. The search engines all fixate on "Mills" as a noun, not a proper noun.
Now that I have it apart, I am even more impressed, the intake side is vented to the crankcase down a hole in the block, so that it self lubricates (a bit) and it has new-looking valves. The intake valves are flappers inside the cylinders, (reed type) and the outputs are disks held down by springs on the top side of the valve plate.
Except for the blown gasket, everything looks fine. The blown gasket is clearly a hand-cut (not original) part, probably blew because the part between the cylinders was too thin, and the material was too thick, still, it lasted more than the 30 years I've used it.
I'm thinking that I could make a new gasket with only holes in it where the valves are, instead of cutting big holes the same size as the cylinder diameter. The bottom of the valve plate is flat, I will check the clearance to the top of the pistons at TDC before doing this. There doesn't seem to be any reason to make the gasket narrow between the cylinders.
Anyway, I would like to find out who made this beast, and where they were, and when, where they came from and who bought the company if it didn't just fold. I am no expert on compressors, but I'm guessing this thing could be from any time in the early to mid 20th century.
Thanks;
John Colt
Thanks;
John Colt
