Gary Ayres
- Jun 25, 2014
Hi -
I recently bought an unusual vintage (or should I say antique) 7-headed milling machine on Ebay in England. The gentleman who sold it to me is an engineer and designer who has over time worked with several leading Swiss watchmaking companies. He bought this machine in Switzerland and had intended to use it in the manufacture of a production run of watch bracelets, but that particular job didn't go through and as far as I'm aware he never used the machine. It's obviously pretty old and is beautifully made. The spindles have metric scales on them.
I e-mailed some photos of it to Tony of lathes.co.uk. He also is unfamiliar with it, but suggested I approach you guys. Tony posted the pictures on the 'Unknown Machines' section of his site - you can see them here.
I will be very interested to hear if any of you know anything about this type of machine, or anything similar to it. For the record, my intention is to set it up with a motor and drive system and use it as a small-scale versatile workstation. I think it will be an interesting job with belts and pulleys, bearing (no pun intended!) in mind that it has seven spindles 'in parallel'.
All the Best,
gary
All the Best,
gary
