Need a cross feed gear...
Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Nov 2017
    Minnesota
    25
    Default Need a cross feed gear...
    I picked up an old Seneca Falls Star lathe, in cleaning and looking at it, I found a gear missing in the apron, it is the gear that drives the cross feed screw. I thought I had identified it, 2" OD, 16 DP, 14.5 PA, a forum member sent me one, and while it is close, it is not right, the teeth don't mesh, they are bigger on the drive gear, I'm not sure if they are 20 pa or something unique, how do you measure them? Below is a picture, the drive gear in the apron is the lower of the two,
    the upper is 2" OD, 16 DP, 14.5 PA. Any help at all would be appreciated, thanks in advance.
    Sep 2010
    moscow,ohio
    4,533
    451
    1350
    measure the OD of the gear, count the teeth.
    Tooth count + 2 divided by the OD
    Take your 16DP gear for example, it is 30 tooth with an OD of 2.00"
    30+2=32
    32 divided by 2.00"=16DP
    Aug 2014
    bainbridge island
    700
    130
    172
    i'd guess and say you need an 18 dp, 14.5 pressure angle gear, and your post is hard to read, no offense.
    find a gear generator on the internet and print out a copy, cut the paper out and see if it meshes.
  4. Likes SouthBendModel34 liked this post
    Jul 2010
    Virginia, USA
    3,171
    76
    509
    that looks more like you need 15 DP here- something custom maybe. Can you measure the OD and tooth count of the drive gear?
    allan
  6. Likes SouthBendModel34 liked this post
  7. #5
    Sep 2010
    moscow,ohio
    4,533
    451
    1350
    My bet it is a 14DP 26 tooth gear that is needed if that 2" requirement is in fact correct...however if that 16DP gear shown in the pic is actually mounted on the stud the 2" is clearly too small...
    14 DP is the red headed step child of the gear world but not impossible to find, many older machines used them.
    but can't tell anything without proper measurements...
  8. Likes Rudd liked this post
  9. #6
    Jul 2003
    savannah, jaw-ja
    1,514
    797
    303
    Quote Originally Posted by iwananew10K View Post
    Oh, they are around - usually found hiding in a piece of stock waiting on a No. 4 cutter and a dividing head
    but seriously - not a hard gear to make if one is set up to make gears. The 27 tooth ones on the 13 tumbler are a bit more of a challenge. (27 being a large prime number)
  10. #7
    Jul 2006
    Australia (Hobart)
    3,056
    421
    2059
    Quote Originally Posted by Rudd View Post
    Since when was 27 a prime?
    WRT 14DP yeah they're hard to find, that's why I've a full set of gear cutters. Been there myself.
    PDW
  11. Likes roadcracks, partsproduction liked this post
  12. #8
    Nov 2017
    Minnesota
    25
    The 2" OD I believe is correct, I had to remove the stud to get the teeth to engage for the picture, with the stud in place, I cannot quite get the two gears to mesh, I suspect I could with a hammer. but obviously they don't match. I'll do a proper pitch measurement tomorrow when I get home.
  13. #9
    Jul 2011
    Americus, Georgia
    257
    344
    56
    search this forum archive for : HOW TO IDENTIFY GEAR PRESSURE ANGLE
  14. #10
    Jul 2003
    savannah, jaw-ja
    1,514
    797
    303
    Quote Originally Posted by PDW View Post
    PDW
    Name me some numbers other than 27 and 1 you can multiply to get 27 as the result.
  15. #11
    Jul 2010
    Virginia, USA
    3,171
    76
    509
    how about 3 and 9
    allan
  16. Likes JBoogie, Erich, sfriedberg liked this post
  17. #12
    Oct 2006
    Midlothian, TX
    279
    249
    88
    ouch...........
  18. #13
    Jul 2003
    savannah, jaw-ja
    1,514
    797
    303
    OK, not posting till after the second cup of coffee from now on.
    I can tell you though that you aren't going to find a 27 tooth gear premade anywhere but the used market.
  19. Likes muckalee liked this post
  20. #14
    Jul 2006
    Australia (Hobart)
    3,056
    421
    2059
    You were probably thinking of 29 which is a prime (AFAIK).
    Agree the gear isn't likely to be found in a commercial catalog. Easy to cut though with a basic DH & appropriate involute cutter.
    PDW
  21. #15
    Nov 2017
    Minnesota
    25
    Okay, the gear the missing gear meshes with in the apron measures 2.565" diameter, 34 teeth. 34+2=36, 36/2.565=14.035. So, 2*14=28, 28-2=26. That would confirm the 14DP, 26 tooth.
  22. #16
    Sep 2010
    moscow,ohio
    4,533
    451
    1350
    ok, you have confirmed 14DP and the machines age pretty much guarantees 14.5 pressure angle.
    But befor you commit to 26 tooth I suggest a little more confirmation...a tooth or so does not make a big difference in outside diameter.
    To that end a center to center distance across the studs would confirm the tooth count, once confirmed a WTB in the tooling and parts for sale section will get you a gear I'm sure.
  23. #17
    Nov 2017
    Minnesota
    25
    Ahhhh. Good call, I'll get that measurement tomorrow.
  24. #18
    Jul 2004
    Houston, TX USA
    27,210
    Quote Originally Posted by wilsonsk View Post
    For 26 and 34, center distance for pair should be close to 2.143"
    Arrived by:
    34/14 + 26/14 / 2
  25. #19
    Sep 2010
    moscow,ohio
    4,533
    451
    1350
    Yup..just add the teeth up(60) and divide by 2x the DP(28)
    clearly a method to the madness.
  26. #20
    Jul 2004
    Houston, TX USA
    27,210
    Have the #4 cutter if you decide its a 26 - you would have to grind it or get it ground like the thumbnail so it cuts without any fooling around
    No charge if you are good at returning stuff
