I need help identifying old metal lathe. I can not find any name plates or numbers anywhere. I have looked inside the frame,bottom of the frame,below the tailstock and below the headstock. I have been searching the web for a lathe bed with the same shape and have had no luck. Here are some measurements I have taken.
15 and 1/4 inches chuck to tail,The height from the bed to center of the tailstock is just over 4 and 1/4 inches. The bed is 30 and 3/4 inches end to end. There is a 2 inch gap in the center of the bed and the bed is 4 and 1/8 inches wide.Any help would be greatly appreciated.
Thank You
Thank You
