Chris M
Cast Iron
- Oct 3, 2005
- New Jersey
I don't have a picture, but if you've seen one of these things, you've likely seen them all. The description should suffice .
cast on single pedestal unit
single-step chrome plated headstock pulley (crowned, for a flat belt presumably. On each side of crown is a *disk* if you will (to keep the belt from slipping off?). These are not separate to the pulley - the *disks* are integral to it.).
yukky remnants of green paint on headstock and bed too (I think)
brass plate riveted to far end of bed, w/a # (can't remember it offhand).
not your typical 3.5" swing, closer to 4.5" (I actually haven't looked at this thing in a while)
something tells me it may take 10mm collets instead of the usual 8mm
I am not in possession of the compound (if there ever was one) nor the tailstock - I sure could use both though.
I'll try and furnish a picture in the next week or so.
THANKS! :O
THANKS! :O
