Joe Michaels
- Apr 3, 2004
- Shandaken, NY, USA
I am doing some work at Hanford Mills Museum during the winter when the Mill is closed. One of the items which is overdue for repair are two (2) shaft couplings on some of the lineshafting. These couplings are "Thermoid" flexible dampener couplings. These couplings use a disc of rubber/canvas with holes for the coupling bolts and bushings.
The material is a multi-layered composite of rubber and canvas, about 1" thick. This material was cut or molded into discs, with six bolt holes- 3 bolts in each coupling hub flange. Steel bushings with fit in these holes. If the bolt circle is not precise, misalignment or worse can result.
I have this same type Thermoid coupling on my old Worthington air compressor, which is direct coupled to its motor. Years ago, I tried to contact Thermoid about a replacement element for this coupling and could not find either Thermoid or a successor. Searches on the internet have not turned up anyone making similar couplings.
The closest to this style of coupling which I had seen was used by Ford on some of their Explorer driveshafts instead of conventional U joints, and this style coupling was also used on some auto steering shafts.
Hanford Mills, being a preserved/working museum, wants to stick with the original couplings, so putting in a more modern coupling is not an option. These couplings may have been put in during the 20's or 30's.
My thoughts as to obtaining a replacement disc for these couplings is to "reverse engineer" and make them. I can have material CNC waterjet cut quite precisely, which I had done to duplicate some heavy synthetic rubber parts when I was working at the powerplant. Finding the rubber/canvas material in 1" thickness is the issue.
An alternative might be to use polyurethane, but I am at a loss as to the proper specfication for polyurethane with approximately equivalent properties to the canvas/rubber.
I would appreciate hearing from any members who can help me with either the source for new canvas/rubber, or polyurethane and the spec/source where we can buy some.
I've been holding my breath with my old Worthington compressor. The dampener element is kind of "petrified" with age (dating to 1947 or thereabouts). The couplings at the Mill are pretty well shot, with the elements even more petrified and cracking and coupling bolt holes wallowed out. Any help will be appreciated, for sure.
Thanks !
Joe Michaels
Thanks !
Joe Michaels
