crrmeyer
Stainless
- Nov 10, 2006
- Southern California
A while back I ran into a 1980's vintage Keller 3D power hacksaw. The good news is it was barely used. While I probably did not need a power hack saw, I was unlikely to find another late vintage one with low wear. So I picked it up. The not-so-good news it that is was a bit abused by the original owner. Half the gib adjustment screws where sheared off. Fortunately they came out with not too much effort.
The one thing it is missing is the main oiler. The catalog photo below shows what a standard one looks like (click on image to make larger).
It looks like the oiler was attached using a 1/8 NPT or similar sized thread. Do you have any recommendations for an oiler? Since it is on the moving part of the saw, I presume it needs to be nominally sealed? Also, for this type usage, would an oiler with a shut-off valve be advised?
Also, does anyone have any oil recommendations? As you can see, it was the one thing rubbed out on the data plate and I do not see any references to oil type in the posted manuals on the vintagemachinery.com. I presume if nothing else I should be using 30 weight non-detergent motor oil or Vactra 2 oil. Though Mobile Vacuoline 1409 (aka old Vactra 2 with added tackifiers) may be the best as it may cling better. I do wish I could find a place to buy gallon quantities of Mobile Vacuoline 1409.
The one thing that does amuse me is that the auto power shutoff arm will try to shear of the oil cup if you open it up too far. I think a few minutes with a grinder will hopefully fix that issue. While the saw it built like a tank I can see a few shortcuts that were taken to try to keep the costs down at that late date.
Thanks for your advise.
