I agree, most rivetting would have been done as "power rivetting", using a "C" frame type of rivetter. Sometimes, this was called a "bull rivetter". In that era, hydraulic machinery using water as the working fluid was common. I was in a very old plate fab shop about 28 years ago, dating to pre 1900. They had a heavy brake, plate punch, and plate shear of that era, hydraulic, still using water. What they had that was also original was a "dead weight accumulator" in the hydraulics. This was simply a mechanical version of the modern "bladder" gas charged hydraulic accumulators. It consisted of a vertical cylinder mounted on the floor. The piston rod stuck straight up, and a massive dead weight was supported on the piston rod. There were two guide bars for the dead weight. A triplex power pump ( 3 plungers, open crankshaft, driven by an electric motor thru gearing) provided pressure to the system. When the shear or brake needed to make a stroke, the accumulator provided pressurized water at sufficient flowrate and volume. Otherwise, the triplex pump would only have allowed a very slow stroke to be made.
In that shop, they had a room with a huge water storage tank, the accumulators, and the triplex pumps. There was a stove in one corner of the room. The foreman explained that in the old days, in winter, that shop was not heated. The men on the floor relied on coke fires in makeshift stoves for localized heat. To keep the accumulator, pumps, and water storage tank from freezing, they had a separate room with a coal fired stove. In sub freezing weather, the cylinders and piping on the shear, punch and brake were drained at each day's end. As time went on, the shop was closed in and heated, so freezing of the hydraulics on the punch, shear and brake was no longer an issue.
In this same shop, the foreman showed me kerosene torches still on the tool crib shelf. A kerosene torch is made of soldered "tin", and looks like a watering can with a wick stuck out the spout. The kerosene torch predated the battery powered flashlight. It was used by shop men to see what they were doing when there was insufficient daylight or the work cast shadows.
The foreman had been there perhaps 35 years, so he would have started there in about 1948. He told me when he started in that shop, there were boilermakers and ironworkers who'd started there 40 years ahead of him, or sometime around 1908-1910. The foreman told me he had heard from those guys what it was like to work in a steel plate shop making tanks, hydro turbine penstocks, dam gates and similar when they started. The conditions would have been similar to a shipyard as the work has a lot of similarities.
One thing I recall from my own younger days was working with older men who'd been in rivetting gangs. These men had worked as either ironworkers or boilermakers. Universally, they were hard of hearing. Most were also what used to be called "punchy", a condition most usually associated with boxers. "Punchy" meant a person had a variety of tics and twitches. Men who rivetted often exhibited this sort of thing, aside from being hard of hearing. These were guys who'd been in field rivetting gangs, using the air rivetting guns.
I drank a lot of beer with those oldtimers back some 35 years ago, and I heard their stories. In the shipyards, the rivetting gangs were often put on a "piece rate" pay scale, meaning the more rivets they drove, the higher their day's pay. It got the men working at a breakneck pace. The record for rivets driven in a single shift in a shipyard was quoted on this bulletin board. If one considers the thousands of rivets that are needed to put a ship together, aside from the need for speed to keep from driving a cold rivet, it was necessary to drive the rivets at an incredble pace. I know with air hammers and a good crew, a rivet can be driven in something like 30 seconds or a little less. with hand hammering, I can;t imagine how fast the rivets were driven. Just to keep ahead of the cooling of the rivets, they had to be moving fast.
In the case of ship building, as noted, all the seams and construction possible was laid out to be done using the power rivetters. These were hung on jib cranes on trolleys, so they could be easily moved into position to rivet the work. As few rivetted joints as possible were left to be done in place by "hand driving". Pre pneumatic tools, hand driving meant what it said. It was a case of having to swing a hammer to drive the rivets. Typically, a rivet snap, which looked like a sledge hammer having a rivet set machined in one face would be held on the projecting shank of the rivet to be driven. One or two men with rivetting hammers would then swing their hammers, striking the rivet snap. A bucker used either a heavy bucking bar or some arrangement of leverage to hold the head of the rivet in place against the plates or flange of a ship's framing.
For an illustration of hand rivetting using the hammers and rivet snap, "The Bull of the Woods" cartoons has a good depiction. It shows a crew rivetting a box girder for a bridge crane using hammers and a rivet snap.
Even after pneumatic rivetting hammers were in common use, it was simply more economical and a better job to lay things out for the use of the power rivetters.
I have an old children's book from about 1912, called "Victories of the Engineer". It was written for perhaps adolescents and goes into surprising detail. It follows the construction of a passenger liner in (possibly) John Brown Shipyard. One of things shown is the rivetting of the hull plating and frames. A picture shows the "building shed and ways". In the picture, numbers of jibs with power rivetters are visible.
I've been in a crew and driven some rivets for locomotive tender frame and boiler work. I have also seen structural rivetting done on bridge repair work when I was a kid. In both cases, rivetting has to be done quickly. The rivets are driven into holes that are deliberately oversized (usually by reaming once the seam or connection is assembled). The rivetting process must then upset forge the rivet shank so it fills and locks in the rivet hole thru the joint or seam. To do this, the rivet has to be at a good forging heat when it is driven. The head is also upset forged when the rivet is driven. As the rivet cools fromt he forging, it draws in and really pulls tight on the joint or seam. A test of how well rivets are driven is to sound them with a hammer. A properly driven rivet has some rebound to the hammer and sounds a good note. An improperly driven rivet (driven with the rivet steel too cold, usually from takng too long in the driving) will often be loose in the joint and will not give a rebound to the hammer. It will sound "dead". Aside from whether the rivet sounds OK, there are the issues of how the head was formed: is it off center, not fully formed, etc ? It is hard enough to drive rivets using hand held air hammers. Pre-pneumatic tools, one can only imagine what it took to drive rivets properly. To try to upset forge a piece OF 5/8" OR 3/4" Diameter steel in one heat with hand hammering is what driving a rivet comes down to. My own guess is that in the pre-pneumatic tool days, rivetted joints were made up with smaller diameter rivets and more of them.
The other issue to consider in building a ship's hull is the calking of the seams. When a rivetted seam is made up, it is not necessarily watertight, no matter how hard the rivets draw the plates together. Calking of the plates is done to seal the seam. It is done by driving a chisel along the edge of a plate overlapping another. This forces some of the overlapping plate into the plate it laps against. Calking was done on boiler work, tank work, hydroelectric turbine casings and penstocks, and ship's hulls when rivetted construction was used. Miles of seams had to be calked, and calkers used air hammers with calking chisels for the purpose. In the days before pneumatic tools, calking seams had to be done using a hand held chisel and hand hammering. Even if the driving of rivets was mostly done using power rivetters, the calking was still a job requiring endless amounts of hand hammering.
Joe Michaels
