irving2008
- Apr 12, 2008
- London, UK
Thought I'd start a new thread on the latest issue to befall my attempts to get my 1924 Relmac lathe operational - how you guys do it with the really big stuff I do not know!
Anyway, having got it all oiled up and running and got the belt tension 'good enough' to turn something I was still concerned about the vibration. I thought this might be a bearing problem, but now I think the spindle is bent.. maybe something fell on it when it was in storage at the previous owner for 6y
I put a MT3 centre in the spindle and put the DTI on it... theres a runout just next to the spindle end of 0.45mm which I'm guessing is rather too much, and I doubt its the centre thats off centre so to speak...
The runout on the main drive pulley is 0.15mm and on the rear shaft out of the headstock (that drives the changewheels) its 0.18mm. I have no idea if these are reasonable but they cant be too far out, can they?
I put the chuck back on and put a short length of 3/4 MS in there and turned it down to 18mm nominal... was actually eccentric 17.99mm - 17.76mm to the best I could measure...
So... the big questions...
Is it likely to be bent?
What else can I do to verify this or not?
Would a worn bearing give the same result?
What should I do next? I suppose getting another spindle made up isn't out of the question, but could this one be trued up and if so, how?
