Joe Michaels
- Apr 3, 2004
- Shandaken, NY, USA
A buddy gave me an old Baldor grinder. Old is likely an understatement, as this grinder has a "square" stator with the laminations visible, and Baldor's address is in St. Louis, Missouri. The general data on the nameplate is 1 1/2 HP, 1725 rpm, and 3 phase. The grinder is old enough that it has screw type grease cups on the motor shaft bearings.
I found the grease cups screwed down hard, no more grease to left to push into the bearings. The grease has the brownish color and smell of the older greases, not what you'd find with automotive greases. I know that is not a lot to go with as far as spec'ing a grease to use in this grinder's bearings. I know the greases from the 50's often were soap based, and did not have the extreme pressure additives nor were they made for higher temperature service like the newer lithium based greases. I know it is not good to mix different types of greases, so want to try to get the correct grease (or at least something with the same type base, that is reasonably close). I'd appreciate any recommendations as to what type grease would be a good match.
The grinder is a bit of a time capsule. It has cast iron wheel guards, work rests, and end shields. The tongue strips (to keep chinks of a disintegrating wheel from flying off the top of the wheel at hitting the operator) are made of 5 /16" thick steel. It has a large brass toggle switch rather than the OSHA=mandated push buttons. Instead of glass shields, there is a porcelain enameled steel sign that says: "Wear goggles when using this machine". I believe the wheel size is 10". I have a Dayton US-made 7" grinder (bought new from Grainger by me some 34 years ago) which I can pick up with one hand. This old Baldor grinder easily weighs close to 200 lbs. The cast iron pedestal it came with (from some other machine) weighs more like 300 lbs. It's a nice old addition to my machine shop. My buddy got it an auction some years ago when an old machine shop on the Brooklyn-Queens border went out of business when the oldtimers retired. The fellows who had that shop were in their 90's, and may well have bought this grinder new. The fact the grinder has the "square" stator and grease cups may well date this grinder to the 30's or 40's. I look forward to using it, and with the good cast iron and plenty of mass in the motor as well as the pedestal, it ought to be a quiet and smooth runner. I'm also curious as to when Baldor moved from St. Louis to Fort Smith, Arkansas.
Thanks-
Joe Michaels
Thanks-
Joe Michaels
