Old motor frame size = unobtainium.
Results 1 to 9 of 9
    Mar 2003
    North Carolina
    1,496
    604
    247
    Default Old motor frame size = unobtainium.
    My old wells index model 40 has a spindle motor made by Master Electric Company in Dayton Ohio. The frame is a 7420 which isn't a frame size I can find the specs on. I am wondering if anyone can tell me the modern cross reference for this size frame? It is a 3ph 1/2 hp motor. I'll be replacing it with a new motor because the bearings sound horrible and I think I have a good 3/4 hp motor I can swap after er a couple of modifications. Oh, the fact that I crashed the fan into the motor windings has absolutely no bearing on my decision to not simply replace the bearings and reuse the motor.
    I'm an idiot. A very pissod off idiot.
    Sent from my Pixel 2 using Tapatalk
    Sep 2002
    gloucester ma
    1,771
    66
    1245
    Quote Originally Posted by challenger View Post
    Consider calling wells for a quote on a new motor
    They are really nice people, even though they do this for a living
    They were so reasonable and helpful when I owned my Wells CNC, that when I scrapped it, I gave them whatever parts they wanted [basically the head] and strapped them to a pallet that they paid to have shipped back 'home'
    They no doubt passed it on to some other WElls owner, like you
  3. Likes MetalCarnage, 44dwarf, digger doug liked this post
    Oct 2010
    Oregon
    4,280
    2853
    1412
    You're right, "7420" is not a standard (even very old) frame size.
    I'm afraid you are going to have to measure a few dimensions. With those dimensions, you can find the closest modern NEMA frame size. To narrow things down, you want a fractional HP (generally two-digit) frame, and the most common examples are 42, 48 and 56, with shaft centerline heights of 2-5/8, 3, and 3-1/2", and shaft diameters of 3/8, 1/2, and 5/8", respectively.
    If you know the shaft centerline height of your 7420 frame, that will help narrow things down a lot. The first two digits of three-digit NEMA frame numbers are 4 times the height in inches. I.e., NEMA frames beginning 28x have a centerline height of 7 inches. Since you can always make a mounting pad/spacer, you should look for frames with your current frame's centerline height, or less.
    Jan 2010
    Indianapolis
    1,216
    715
    374
    Dealing with physical objects is so much harder than managing people.
    Damage a person, just call HR for another.
  6. Likes tdmidget liked this post
  7. #5
    Mar 2003
    North Carolina
    1,496
    604
    247
    Quote Originally Posted by sfriedberg View Post
    You are correct.
    I have taken some measurements and compared them to the NEMA charts and this motor is a long way off. Nothing that a bit of mounting plate and pulley sheave modifications won't address.
    For giggles I'll call the local motor rewinding shop to see what the cost to rewind and rebuild the motor will run. Last one I had done was a Baldor 5hp single phase compressor motor. It was $400.00 to rebuild and a new one was more than that so I had them do it. This time I really doubt I'll be inclined to do so.
  8. #6
    Mar 2007
    L'Orignal, Ontario Canada
    1,744
    990
    602
    I don’t know a lot about electric motors but I have seen at least one instance where a motor with damaged windings that had special rotor and end bells was salvaged by taking the stator or center section with the windings from another used motor of the same physical size HP. and voltage and putting it together with the rotor and end bells of the burned out motor .
    You might be lucky enough to find a used motor that could donate the stator and put in a new pair of bearings to get you going again .
  9. #7
    Dec 2008
    New York
    8,386
    2241
    many motors if you can manage to get it apart, changing bearings is relatively easy. some motors getting apart can be a challenge, sometimes rusted solid or they used the high strength loctite never made for taking stuff apart
  10. #8
    Mar 2003
    North Carolina
    1,496
    604
    247
    This was very easy to get apart and easier to make the fan blades ruin the armature wiring.
  11. #9
    Dec 2008
    New York
    8,386
    2241
    many a motor i flopped upside down clamped on a hardened steel plate with holes in it to guide a drill bit as i drilled 1/2 a hole or slotted the holes.
    they also sell hardened drill bushings that can be pressed in soft steel to do same thing. and soft steel good enough to guide a hole saw with pilot removed to also cut 1/2 a hole or slot holes
    or use a rotary file in a hand held grinder to slot the holes.
    most millwrights would have any motor even remotely close to size bolted on in less than 10 minutes. sure if motor over 500 lbs might take a extra 5 minutes
