conant
Stainless
- May 13, 2013
- Shasta County, Ca. USA
We have recieved a American Tool Works Model C 16x126 Lathe with the 2 speed tailstock and the Bijur pump.
I topped off the reservoir with fresh way lube to the level on the site glass. I then noticed a leak below the pump plunger area. It was weeping out of the .050, or close to that, hole dead center under the pump plunger and on the same plane as the pump mounting holes. It is too accurately located to being not meant to be so I ignored it.
Sure enough the slow leak eventualy empied the reservoir and a piddle of oil on the front way the length of the bed.
Is this a vent? Possibly the wrong pump flange that was intended for a vertical pump set up Or possibly a tattle tale for the oiling system needing attention? Similar to the weep hole in a water pump on an automobile?
Haven't had a chance to dissasemble yet.
Anyone else here experienced this
