OT: A Snow Run with the Lombard (sort of)
Terry Harper
Cast Iron
Sep 3, 2009
Maine USA
What better way to spend a sunny 35 degree February day than by playing with old machinery?
Yesterday morning we headed south down I-95 from "The County" If your from away you probably don't know
the significance of those simple words but if your from Maine when somebody says "the county" you
know instantly that they mean Aroostook County - which, by the way, is the largest county east of the Rockies.
Anyway, after a 2-1/2 hour ride we arrived at the museum, met up with Herb and went to work. First order of business was sorting out the fuel system. Last time we ran it the old girl wasn't running so great. I thought it might be water in the fuel but as it turned out is was sediment from the tank. Cleaning out the bowl and a little filter screen in the carb as well as cutting in a in-line fuel filter took care of that.
We also looked at adjusting the tracks which are very loose. Not wanting to break a bunch of bolts we decided that a little heat would help. However the thought of dragging the torch setup through the snow convinced us that its a job better left for the next trip.
All this work, of course, required us to take the beast out for a test run. Since we have had a nice thaw with a bunch of rain thrown in the snow banks are not what they were but the once at the road was just a solid ice bank. I had visions of 23,000 lbs of Lombard framed and teetering on the top like the Grinch's sleigh on the tip of Mount Crumpet. Not something I wanted to contemplate. As luck would have it they are harvesting trees blown down from a recent storm and it didn't take Herb long to convince the skidder operator to knock a hole for us.
All good fun!
sZxf26uVX_QbbAlzMFPPTP7DZUMRicbJ97KCIPWvlKAY16ItAh  qIgrVSuOz-ln580MY6Ets5KPG89MZXvBcft7VIYTYYagJ8STJc2K5UejXxyI  3ePf81tVgUHMXXJot51uDeeI-oe8lE3Bmnlt1cZfl_KY_hgmVfxwdpVkYb2O_zxTU55UhT93emn  rpkkanngA2FmFNfW6kU3RWwakcsYgO4CrYX0mGqGkpmhpk6JJi  EnZ_YQwg_KnMNGV2mKcjXbHmdbrV4cwcv0YELgRUzzN01Nm0K3  Fj5FINdFl1iLpircUObtdFsaNapAe6_GdtOtVrSRdqqDVuj-r17QYz7bd55v679l-9O6e7TTJMu1MhW5vYM6aIVs5Foc0-nDEsUrGh0rBf21ai_bRIXUEnDfAIsUV4IYgCeUrjfBz1G9qEz6  6vO2a715LvS0sMDZmNKnuiIPPwoc6nFcSBEQ-1pe77YvfJ68FBvsAywdrQXjSIWBQ_2WyPdijOpu_siqzYNa8jO  74FTblvjx1nfc8l9WVlgIWWkOEbfLeoEEfr4a5eyy8YELYdpOE-Z88r3yLMOHfjQ8fXOGGiwNosKEalKGARJQYv_qpmh4H0UOb8=w  1599-h1072-no
gHq17N6gAPEA5Zb6niedzXgkOljDHXRlHw9cbQz3wX2pup8jmB  stEQj7mtTrl0GwEcJ1Gpqor0FsJou7KBo-p_aMgxJtW3efXVvfpSjQdEWrNLS6y9-E5IcgDf1u5R4w4MSXah4NEgZWc8xUN30LQNZ98cJhuqplacu9i  79dxob-8ISrHwLEcwC9H5PsnlBB05wW-sAS-P-0Hu9fF-MuK11fJ2vVUKjvlC85-iOHKXXw4p-yU8m2z4-BLRqlfrKRouHrb71RKOObfnbmD6GGHhepihdm2c6DsLPvNydzj  MafA70en56M4npMld6sUsek6G7GKqEc0T1B_AEAz016ps-s5R1F7Kcgq5tjjwA4nrG5mOICzAZinux6f5dRjou6V2XDgDTWb  nQt25SPT--JXkuDstRisfjwQ_JN4MFr0_JcH68BsI5BbNKQi9QrO5xmkgKy8  TZHanwJCCjkkFafMnIOuS9kk-b39zolBCVUbU8kw4dAl2kAeH8GLKo5UOGnxkW9xxgROOrrxc_6  eWkx4zma0fTxTTSCJpofuFFe6gRe5H9e-ZUHPsCsMoUZ1YaZik89zaYp14alzS50Fi6AbzWtrjdpuq8oRBU  S0aY=w1599-h1072-no
Pibc33umlWy1blUWZYLhmyMLvYZdmqNxOvWW669IS367rI0ukv  PrPVncyEqdeMnf3pJ1rjuoj-EADdIqVbrOZ9EhONUVvz8dQb0NcJz7iCknM0Y43nScdI_i1rDm  c68yS7Pc8RtKjvdFFBsps_D2L3N-ApXX8W0EAreyFKEaNvgV0bg-lexj1Oz3IBPxhMnMLyMwRlwGUDgsdomNLC-PLzDWJaDAQnrnfs_HJee33BJAnZqxG-hOrPgoBsmPbS_e0oAhCcNG2b64pawZICUjQ6ig6IFX859myDUx  oIF4OFSv0UFicbFSjqIu3z0AdIE5Y8EdHbF3Nn3vTBBobiExWn  _5zAHWoN1R8bH5a3Qtp5xxw4MnI3fczvUTZRGbLXhtjfsBCqVC  nkyBbpzVx_HBahc4dexvO5JQC8h1NV1exLe7NK-gPnwciHL46r4FqCttSHzj0DleaJxTUtKU_ebYv8vQGiF-HI4mJa706kfk5hhvgyZRMrwOH89OlHCLY66r6yQmJZ3wbhenCl  eLWjkTVuC0V4AFBEYg9a4dXjupB15aMciUOAFD19mNZaOJqeG6  Iqao-bzHkxlBuWKl76ALXkI7GPWvu-eodC5gd-U=w1599-h1072-no
Thank you for the post. Very cool! So what kind of motor runs this little beastly log hauler? Figure maybe a Buda or LeRoi? What a great way to spend a Feb day, much better spent than mine! Congrats on a job well done. That is just awesome. Regards, John.
Hello John, Originally it had a 6 cylinder Wisconsin D4 (5-3/4"x6-1/2") that according to the brochure cranked out 145 hp and almost 700 feet of torque but.... years ago the chassis and engine parted ways so it was re-engine with some odd 6 cylinder engine with what looks like Hindu writing on the tag. We have to run two transmissions with the first locked in low gear. We would love to find the correct engine for it or even a D2 OR D3!
Adjusting up the tracks.
Do they have a large spring near the adjusting nut & front
idler fork ? Like on a dozer ?
Usually they are covered up, and hard to see.
If you have such an arrangement, I would make
sure the spring isn't broken.
Hello Doug,
The yoke has four slots (two on each side for the bolts that hold it tight to the underside of the frame rails.
The adjustment bolts are two long bolts extending from the front of the yoke through a frame cross member. To adjust you simply loosen the four bolts so they will slide in the slots and take-up the slack with the adjustment bolts then re-tighten everything. The attached patent drawing explains it the best. Once we break everything free of rust and layers of paint it should be a quick process.
I used to know something about truck cooling systems, so I am curious about the gas Lombard. I see it has a Boyce MotoMeter with a Lombard logo on the front mounted on the top tank of the radiator, so I guess it was OEM. I also see a manually operated radiator shutter. Can the driver really see the top tank temperature well enough to know when to adjust the shutter?
Is that a starting crank on the front? That crank looks wicked, and not so fun compared to the actual joy riding once it is running.
That thing looks like child's play to operate compared to the steam Lombards.
Larry
Hi Larry,
Yup, the MotoMeter was OEM. However, the original went missing way long ago so what you see here is a replacement - The body is an original and since getting our hands on an original Lombard faceplate would be difficult to say the least I etched a new one using an original (provided by a collector) as the pattern.
I can tell you for certain that I can't read it! That radiator is out there some. However, sometimes they would mount a little light on the hood to illuminate it at night. My guess is that the shutter served more to protect the radiator than help with cooling.
Yup! That is a crank handle. This one got a bit bent at some point. Once the museum's blacksmith shop is up and running again its going to get a little TLC. It is an experience cranking one of these beasts by hand. There is one period article I found where they were using a Lombard to clear farm land down in New Jersey - When the starter or battery packed-up they used a rope and several burly gents to pull it over. My friend Don has a Lombard with the original 6 cylinder T-head (5-3/4"x7") I have tried to hand crank it several times. I simply cannot pull it through - and I am 6'-2" 240 lbs. Don is few inches taller and he makes it look like childs play.
Old Photo of Gas Lombard with the Ski Attachment
Terry,
On the Lumberman's Museum website, I found this old photo of _what I think is_ a Gas Lombard with the ski attachment.
past perfect 1 images 328 | The Patten Lumbermen's Museum
Can you confirm that I've correctly identified the subject as a Lombard?
Note that she's towing six, count them, SIX (!) sleds piled high with pulpwood! Sleds don't have brakes!
On Edit: Here's another: past perfect 1 images 228 | The Patten Lumbermen's Museum
John Ruth
Yup! Those are Lombards! The second link is to a photo of Ed Lacroix's tractor no. 6. That particular tractor survived and is now in State Museum in Augusta. At one time Lacroix operated upwards of 20 or more Lombards. He was by far Lombards biggest customer.
6 sled! That's nothing. The record load was 298 tons (108 cords) of pulp wood loaded onto 22 sleds. It was set using the one and only diesel powered Lombard which had a Fairbanks-Morse 36A 5-1/2 engine. Here is a video showing that particular tractor in action.
Prior to that the record for a standard gasoline powered Lombard was 264 tons (96 cords)set in 1926.
I counted 13 sleds in this photo:
Here is a photo of the diesel:
Maine Logging "What's Its"
The Patten Lumberman's Museum website has dozens of historic photos without captions.
Patten Lumberman's Museum Image 284: An Avery tractor. Only steamer I've ever seen with the engine below the boiler.
past perfect 1 images 284 | The Patten Lumbermen's Museum
Image 319: Lombard's transporter. Not sure I'd like to be UNDERNEATH while manhandling the starting crank!
past perfect 1 images 319 | The Patten Lumbermen's Museum
Image 336: Non-Lombard Track. Rivets give it a WW 1 tank-like appearance.
past perfect 1 images 336 | The Patten Lumbermen's Museum
Image 381: I think this is the enginehouse at Umbazooksus Lake. I think I recognize it from an article in a long-ago issue of Down East magazine. The engine house has since burned, but the locomotives are still there. Terry has a thread somewhere in this forum about stabilizing the track under these now-exposed locomotives and jacking them back upright. He saved them from capsizing! This is a lot harder to do in the remote wild woods of Maine than you might at first think! Hurrah for Terry and his crew!
past perfect 1 images 381 | The Patten Lumbermen's Museum
Added as an afterthought, just because it's so strange:
Image 164 - An impractical-looking worm-drive tractor.
past perfect 1 images 164 | The Patten Lumbermen's Museum
John Ruth
Hello John,
That flatbed Lombard dates to 1909. Lombard made his first Gasoline tractor that year. His very first gasoline tractor was pretty much a steam Lombard frame and track system with a huge (9"x10") Brennan four cylinder engine mounted on the back. a set of cast iron radiators served for cooling.
The armored crawler tractor would have been originally intended for service in France during WW1. after the war many found their way into the woods.
The screw driven machine was designed and patented by Ira Peavey. He also developed a gasoline version as well. Somewhere I have a photo of both a Peavey and a Lombard working on the same operation.
Yup that's the engine house that was at Tramway. The locomotives were stored in it until the state burned it down in 1968.
I can't believe its been over 20 years since we did that project! In fact it was about this time of year when we had the infamous pickle pail incident. We hauled 150 yards of crushed 3 miles across Chamberlain Lake using snowmobiles and 5 gallon plastic pails. In all it took two weekends and 4500 pailfulls.
What great memories!
