tgw
- Dec 21, 2005
- Central Texas
I know this isn't the place for welding questions so if it needs to be moved please do.
The man that runs the local scrap yard gave me a couple of pieces of brass rod that were mixed in with some common brazing rods. As you can see from the photo they are square shape and folded from a strip of flat brass. The middle is packed with white powder that I would guess is flux. I melted a little of the rod and it acted like common flux.
I have been brazing for a long time but I've never seen any rods like this. I learned to braze on cast iron oil field equipment and tractor parts using plain old brass rod dipped in a can of Brazo flux. We always had lots of pump housings and engine blocks that had "hard water problems" this time of year.
I just wonder if this is something that was common?
Terry
Terry
