Welcome back, Lathefan!
What is the purpose of that husky overarm bar sticking out of the headstock? ?
JRR
JRR
Excellent photograph. No safety glasses! No computer! I like it.
Good observation about CI, Limy.
I usually bore at the 3 o'clock position of the bore, viewed from the turret. In this photograph, is that a boring bar cutting at the 12 o'clock position? I never thought about doing that, I suppose because I don't have a vertical milling attachment. I can see that there could be arguments for doing this, such as having gravity tending to keep the boring swarf away from the cutter. And then of course there are considerations that can be dictated by setups for simultaneous operations in two orthogonal directions.
-Marty-
Marty --
One of the major makers of turret lathes (can't say for sure if it was W&S) published a "how to use a turret lathe efficiently" book that specifically recommended positioning the boring bit at the top, to minimize the effect of turret-indexing variability on bore diameter.
John
Nice one Lathefan, and welcome home mate.
A Type (Saddle Turret) Warner & Swasey by the look of things (one of the smaller ones), .............that ones fitted with the taper turning gear on the front saddle cross slide.
FWIW that's comparatively rare pic of how a turret lathe ''should'' be used - more than 1 tool in the cut at the same time, .........made so much easier with the wide use of carbide tooling, I.E. you can maintain a good rate of cut on the smaller bore without burning up the larger OD tool .......going by the dust the job looks like CI to me.
Tyrones right about the pilot / steady bar, ....I've lost count of the number of times I've banged me nut on them, .....for those that don't know, the partially visible turret station on the extreme right carries the bush to align with the pilot bar, and judging by the shape of the tool in that station it carries more than 1 cutter.
Am I correct that the saddle does not span the ways? If that is correct, is a guide way on the bottom of the apron?
Tom
Notice
