magneticanomaly
Titanium
- Mar 22, 2007
- On Elk Mountain, West Virginia, USA
Machines with anti-friction bearings can run faster than the old plain bearings, so it is said.
But, why? Engines running at 7,000RPM and turbochargers going much faster use plain bearings, albeit with pressure lubrication.
Why could not an old lathe be run at carbide speeds, if you ran enough oil through it to keep the bearing temperature reasonable (might be messy!)?
