Ruppster
- Aug 6, 2014
- MacDill AFB (Tampa), FL
Okay, a few weeks back I posted about a Garvin horizontal mill I was playing with and mentioned a B&S mill that the Garvin seller had also. Turns out it's a model 1B Plain Horizontal Mill. Last patent date on it is 1907. Now I'm thinking of getting it too and seeing what I can do with it. My questions are about the aftermarket vertical head that's on it. At least what's left of it.
The seller said it was an Edlund vertical head, yet the tag I saw on it said something like Universal Tool and Machine Co. or Universal Machine and Tool Co. (sorry, it was early and the coffee hadn't kicked in yet). Anyone have any ideas as to who made the vertical head based on what little is left? I tried searching for info about vertical heads from either company and was not able to find anything. The handle/wheel for the vertical spindle drawbar on top appears to be secured in place. It will rotate but will not lift up and out.
Worst case scenario my thoughts were it shouldn't be too hard to fabricate a motor mount that clamps to the vertical spindle mount. The seller has had no luck selling it and is about to send it to the scrap yard.
On a different not, the catalog I've seen with this model show it as a belt driven mill (1916 B&S catalog). Yet the mounting points for the motor mount on the rear appear to be machined into the base of the main casting. I take it this was electric powered from the start by B&S and not originally belt driven?
Speaking of different notes, I want to give a big shout out to forum member stevewatr. He has a series of Youtube videos where he takes apart a B&S model 2B plain horizontal mill. Learned quite a lot about how to take apart the 1B from them and that will be a big help should I pick it up. Thanks Steve.
