Salem Straub
Cast Iron
- May 22, 2012
- WA, USA
Reed Prentice ... did they make lathes in the 1950's larger than 16"? (was P&W)
A lathe came up for sale locally, I got a quick look at it but was focused elsewhere... it's a Reed Prentice made in the 50's, and I saw it's a gearhead, it's gotta be at least 20" and I think maybe 24" center height, with 10' or so between centers, and a top speed of 500 rpm or so IIRC.
I guess these did not have hard ways, so I'll be sure to check the bed carefully, especially up near the headstock... and I've read that RP had gear tooth breakage issues more than some other lathes, so I'll need to check that as thoroughly as possible. I think it can be powered up and ran where it sits.
Anything else specific to larger Reed Prentice lathes to consider? Would you say it's about like a similar LeBlond in terms of rigidity and precision (very good but not up there quite with L&S, ATW, Monarch, Axelson)?
Thanks for any info!
