Greg Menke
- Feb 22, 2004
- Baltimore, MD, USA
I have a little Wade 7" turret lathe, it uses Wade collets in the spindle which are pretty much like 5c's (but no internal threads). It uses a lever closer and draw-tube, nothing unusual.
I was doing a bar feed job a short while ago, feeding the bar by hand onto a stop in the turret- which was fine but it had the usual problem of the collet pulling the work back when closing. I held the stock against the stop while closing but thats kind of a pain, collet tension can be finicky and sometimes several attempts are needed if the work shifts and the fiddling around soaks up time.
I'm happy with the internal work stop mounted in the tube or collet as the case may be if I have cut parts to load, my question is about bar feed. My bar jobs don't have long stock- maybe 2' at the most. I heard one person made a cylinder of pvc and a wooden piston, fit to the spindle assy and driven by compressed air to keep the bar pushed onto the work stop. I don't have the right air system nor big enough repeating bar jobs for something like that to be a big payoff, so I was hoping to find some simple ideas to avoid manually holding the work while operating the closer. For instance, some kind of ram on its own lever to push the stock once the outside end is inside the spindle might work but I'm sure something like that also leads to complexity- to wit feed fingers on screw machines.
Thanks!
Greg
Thanks!
Greg
