Romak
- Nov 2, 2011
- Surrey, BC
Good evening everybody.
Today I discovered an unusual mechanism that might be made in 1860's-1900's. The mechanism consist of a big gear and a small gear attached on a wooden panel. It seems like the mechanism was repainted recently, since paint in pretty good condition. The gears are cast and you can see that the pattern made of wood was used for casting. I am really puzzled about the purpose of such mechanism and what machinery might used it. The interesting thing is a wooden shaft or a hub attached to a smaller pinion. The shaft has two square holes on each side and the holes are cut like pyramids. They both wider at the bottom and narrower at the top. I am not sure what might be placed in such holes. The bigger gear might have a crank attached to its square hub. The mechanism is 21 inches height and big gear is 13 1/2 inches in diameter. The iron base at the bottom has three smaller holes and one big hole that was probably used to attach the mechanism to a flat surface. Square nuts also suggest that mechanism is from 1800's or early 1900's. Please, let me know what do you think. I also noticed that there is no any numbers on any parts. Usually mass produced machines would have numbers of the parts but in this case everything seems like is unknown.
Thank you very much!
