Results 1 to 20 of 20
    Scrap Master44 is offline Plastic
    Sep 2007
    Dalhousie N.B. canada
    11
    Post
    Hello,looking for Info on an OLD Becker/Brainard Universal horizontal milling machine, Pat # 734837and734838 July 28 1903.
    Eric LaVelle is offline Cast Iron
    Aug 2004
    Belleville, IL
    411
    Post
    I have a #2. Let me know what you need to know. I haven't run it, but I have done a total disassembly, cleanup, and repair of a couple broken parts.
    Eric
    SteveM is offline Titanium
    Sep 2005
    Connecticut
    3,280
    Post
    Eric - I have an older one (think it's between 1888 and 1898) that is only labelled as Brainard. I'd be interested in seeing pictures of yours. Do you have any you can post?
    If you haven't already, you can see pics of mine here:
    Brainard Mill
    Steve
    Aug 2004
    Belleville, IL
    411
    Post
    Steve,
    I'll see about getting some pics tomorrow for you. It's very different from your machine.
    Eric
    Aug 2004
    Belleville, IL
    411
    Post
    Well, I finally got some pics taken of my mill. I'm not happy with them though, as the flash seemed to magnify every flaw in my cleanup and repaint. It looks rusty in the pics, but it isn't. Everything moves very smoothly. First, here's how it looked last winter:
    And after the cleanup, repaint, and reassemble:
    Not perfect, but as perfect as it's going to get for now.
    Eric
    J Grainger is offline Aluminum
    Oct 2006
    United Kingdom
    221
    Post
    I cant add any information but I'll say it's not such a bad job you've done there.. Dont worry too much about the colour.
    J Grainger
    Feb 2004
    Metuchen, NJ, USA
    4,645
    Post
    That's not "rust", it's "patina"
    Tell us how you did the spiffy job on the raised letters......what paints and techniques were used?
    John
    Aug 2004
    Belleville, IL
    411
    Post
    John,
    All I did was hand a can of Oneshot sign painter's paint and some small paint brushes to my wife. She took care of the lettering. I use that paint on the lettering of all my old machines. I also used it to pinstripe my wood planer.
    Eric
    lenny baledge is offline Cast Iron
    Feb 2006
    NW Arkansas
    354
    Post
    Eric,
    Is this the mill that inspired your signature on owwm?
    Great looking machine.
    Lenny
    Aug 2004
    Belleville, IL
    411
    Post
    Lenny,
    Yeah, the teardown took me forever and the reassembly of the knee was awful. It took me a week of 8 hour days to get it back together. I kept putting the parts together in the wrong sequence, tearing it down again, and reassembling until I got it right. It was probably more difficult a restoration than the Sweepstakes planer.
    Eric
  11. #11
    Sep 2005
    Connecticut
    3,280
    Post
    Wow. Now I'm grateful that the prior owner of mine talked me out of disassembling the knee for transport.
    All you guys with Brainard and Becker/Brainard mills: We need to get together a bunch of good quality pictures to Tony at www.lathes.co.uk . He's got nothing on these and would be very interested. I promised him pictures of mine when I get it set up.
    Eric - thanks for the pictures. When I go to assemble mine, I''ll probably be coming back to you for some details and pictures, especially the table feed. I have a box of parts and no information as to how it goes together (sort of like your "before" picture.
    Steve
  12. #12
    Aug 2004
    Belleville, IL
    411
    Post
    Steve,
    I can walk you through the reassembly of the table mechanisms. Is the top of the saddle still on the knee or is it removed also? The major problem with this machine is that you have to remove all the guts of the knee to get the lower part of the saddle off the machine. That's the only reason I took it completely apart.
    As for getting pics to Tony I'll go back over the ways of mine with some scotch brite until I can get more satisfactory pics. I tend to be very conservative in how much I work on the ways of metalworking machines due to fear of removing metal.
    Eric
  13. #13
    Sep 2007
    11
    Smile #3 Becker mill
    Quote Originally Posted by Eric LaVelle View Post
    Eric
    Dear sir,
    Sorry I'm replying so late. I've seen the work you've done on your machine and I have to say It looks pretty good.Haven't torn down mine yet, I have nearly finished the re-assembly of my Cunliffe&Croom mill.Can't tear down 2 at the same time(not enough room to prevent parts mixup). One question I have about your mill, how were you Intending to drive the flat belt pulley? My mill has an "auto drive", four speed, two handle gear box mounted above the mill, with the motor above the gear box. It turns too fast and as luck would have It, the back gears (large and small mating gears) are totally ruined. I've tried to send pics to this site, but haven't had any luck so far.Hope to hear from you soon,
    Scott MacKenzie
  14. #14
    Nov 2007
    sudbury on canada
    Default no.5 vertical becker-brainard mill
    Quote Originally Posted by SteveM View Post
    Steve
    I;m looking for specs for my no. 5 vertical mill (becker-brainard).I gotitW 25 years ago in Detroit
    I worked in a forging plant were we made connecting rods for Ford&Chrysler.We would get the master dies from Toronto and Detroit then sink a whole bunch from those masters on a mill identical to the one I have.I know I`ll probably never find a work shop manual for it but I would greatly appreciate any info on this mill.
    Clem
  15. #15
    wem
    wem is offline Plastic
    Apr 2008
    coast of Maine
    8
    Default Becker
    I have an old one coming. No Brainard name just Becker. I'll have to find another flat belt driver.
  16. #16
    Pete22 is offline Cast Iron
    May 2003
    Branford, CT USA
    272
    Just as a point of interest here is a picture of my Brainard "STANDARD UNIVERSAL NUMBER 5"
    Made by; Brainard Milling Machine Company
    Boston, USA
    Patented Oct. 1 1872
    As near as I can figure, this predates Brainard's merger with Becker. I suspect this mill is about 1890 vintage.
    It is in pristine shape and shows little use.
  17. #17
    Robert Lang is offline Stainless
    Apr 2007
    Minneapolis, MN
    1,108
    Quote Originally Posted by Pete22 View Post
    More like the early to mid 1880's for vintage.
    Rob
  18. #18
    peter is offline Titanium
    Mar 2001
    New England
    2,793
    Pete22, Is your No5 a bench top miller or mounted on a factory base?
  19. #19
    Apr 2007
    Minneapolis, MN
    1,108
    Peter,
    Pete22's mill is a floor model. It is mounted on four factory legs. The chip pan is not original.
    Rob
  20. #20
    Mar 2001
    New England
    2,793
    Ah, too bad.
    thanks Rob.
