peter
Titanium
- Mar 20, 2001
- New England
I know this is way OT, But; the expertise on this forum is such I am sure I can get ideas.
I have a Kubota 4wd tractor with a slight leak at the front axle, where the wheels pivot when steering. There is some school of though that the lack of an axle vent aggravates this leaking, which apparently is common on Kubota. Or atleast common as the seals wear. These leave the factory with hydro oil. That usually get replaced with gear oil after some specified service interval. I just today replaced the fluid (1000 hrs and 12 years later). Seals maybe next. I understand, sometimes gear oil is enough to reduce or eliminate the leak.
I though a small breather might be good insurance. Certainly if I do the seals, like it to be the last time.
Any opinions on this idea? Heat and expansion, contributing to fluid leaking out from a sealed axle unit?
I can easily drill and tap 1/4 pipe into the filler cap. Is there a cheap simple breather off the shelf that just screw on? Maybe a gitts flip up oil cup filled with steel wool?
Or is this a lot of fuss about nothing?
