Results 1 to 7 of 7
    Old Iron's Avatar
    Old Iron is offline Hot Rolled
    Jan 2008
    Andalusia, Alabama
    781
    Default LeBlond regal thread dial.
    I don't think I'll ever find one so I checked out the one on my 13" south bend. It will work if you turn the gear around and drill and tap a new whole.
    the gear matchs up perfect so being as I have 2 I'm going to do the mod and use one on the regal.
    Paul
    Mike C. is offline Diamond
    Nov 2004
    Birmingham, AL
    9,816
    As long as the leadscrew thread pitch is the same, it should be no problem. Even threads on any line, odd threads on any numbered line for half nut engagement on that LeBlond.
    S_W_Bausch is offline Diamond
    Jan 2010
    Indianapolis, Indiana, USA
    4,586
    John Oder speaks of a hand-carved thread dial pinion, others have posted photos of wooden threading dial cases.
    Pretty forgiving of what/how it's made, as long as your replacement candidate has little chance of damaging the leadscrew.
    k3vyl is offline Hot Rolled
    Feb 2008
    newark DE USA
    656
    The SBL is a nicer dial,and the gear is wider.I have both lathes and both dials.I would not try to use the regal dial on the SBL because of the slotted lead screw.If that narrow pinion gear ever caught the slot,bad things could happen.The other way around is no problem,theres no slot and the gear is generous.
    Jan 2010
    4,586
    Default Good observation, good advice
    Quote Originally Posted by k3vyl View Post
    Good observation, good advice.
    Old Iron's Avatar
    Jan 2008
    Andalusia, Alabama
    781
    Thanks for the help, I checked it out before posting didn't want to get run out of the country.
    Paul
    Bret Rochotte is offline Cast Iron
    Mar 2008
    New Bremen, Ohio
    277
    I have a thread dial from an old 14" LeBlond, the pinion is in bad shape though. Let me know if you would like to see pictures or measurements.
    Bret
