Montgomery Ward Metal Lathe
Community On The Web
Results 1 to 8 of 8
    1swede1 is offline Junior Member
    May 2005
    Sacramento, CA
    Post
    Can anyone tell me about this machine? Its model 04TLC-700A. I just got it and don't know much.
    Dave A is offline Titanium
    Jan 2005
    Roseville, CA
    3,861
    Post
    Could you post some dimensions and other information? Possibly a photo?
    JST's Avatar
    JST
    JST is offline Diamond
    Jun 2001
    St Louis
    12,668
    Post
    The model number is probably the 700, the other part makes no particular sense.
    If it is a Monkey Wards metal lathe, it should be a Logan, and probably will resemble this
    ahall is offline Stainless
    Aug 2004
    OK, USA
    1,432
    Post
    Monkey wards lathes are usualy logans.
    The little pull knob on the headstock is a dead give away its not a south bend.
    JST's Avatar
    JST
    Jun 2001
    St Louis
    12,668
    Post
    Well, now I've seen pics of the machine including the nameplate, and it is a Logan.
    And the model number is exactly as given above.....I guess Monkey Wards added some numbers. The 04TLC part is right on the plate.
    larry_g is offline Cast Iron
    Mar 2004
    Salem, OR, USA
    361
    Post
    The wards lathes were made by Logan. There is a logan lathe group at http://groups.yahoo.com/group/lathe-list/
    Contact Scott at Logan and he will give you information on the lathe and sell you the manual.
    lg
    no neat sig line
    Rob
    Rob is offline Member
    Aug 2005
    USA
    85
    Post
    It IS a Montgomery Ward lathe. I just bought one with the same model number. It has a 10 inch swing.
    May 2005
    Sacramento, CA
    Post
    Thanks to everyone for the help with this lathe. I found the place that sells all the parts for it. (though NOT cheap)
    Again, thank you all for your help.
