alskdjfhg
- Feb 20, 2013
- Houston TX
This is a continuation of an older thread started by JohnO;
http://www.practicalmachinist.com/vb/antique-machinery-history/fair-size-hendey-houston-289506/
Here is the Hendeyman rundown of this machine's history;
alskdjfhq:
Posting the serial number is making sense out of the dimensions that were listed in the ad. As I had thought, this was a special order lathe that exceeded the normal maximum bed length for a 24 inch Geared Head lathe. Hendey lathe #23751 is a 24 x 30 Geared Head model built on October 6, 1920. It is considered a 1918 model design and was shipped with a Taper Attachment and an extra Steady Rest. The center to
center distance will be 293 inches with the Tailstock flush with the end of the bed. The Centers used are Morse-Hendey #5 and the Center Bushing is a Morse-Hendey #6. Spindle bore is 1-3/4 inches. Speed Ranges are 10rpm to 320rpm. As I mentioned in a previous post it has nine speeds. Screw cutting range is 1 to 56 tpi. It uses the old style 4 tpi Leadscrew that was changed to the 2 tpi Leadscrew in 1924. The original owner was the Joshua Hendy Iron Works, Sunnyvale, California. Sans motor, it should weigh about 15,550 lbs. Very few Repair Parts are left in inventory, but all of the original drawings are still in the files, so parts can be made.
Hendeyman
Here are the pictures from today, since there are more than 5, I used Photobucket to host them, hope the link works.
The pictures depict the process by which the lathe was rotated 180 degress.
Moving The Hendey Photos by mebunting | Photobucket
The big forklift is a 25,000lb capacity machine and there has to be something wrong with it, it was straining to lift the headstock end and would not hold the lathe in the air, also the forks were visibly flexing and allowed the lathe to slide down the forks.
The pucker factor was ENORMOUS. The guy spotting the forklift drivers was a complete moron, and the guy driving the little forklift was totally out to lunch. They about dropped the lathe twice, and broke two of the leadscrew counter balances.
Loading only took about 15min, but it was a terrifying 15min.
The trailer is technically only rated to 10,000lbs (two 7k axels), and it's 24ft long with a 3ft dovetail. So yes, you can say we were a bit overloaded.....
As we were going down the road at 20 miles an hour, something interesting happened. A fellow in a Mercedes, pulled along side (since the truck's A/C isn't working the windows were down)and as we were moving, asked if we wanted to sell the lathe. Since it was time to check tires, chains and wheel bearings we pulled over. He fell all over himself to offer me $5,000 for it sight unseen.
So is this guy a fluke? Should I snap at the chance to get 5 grand for it? I'm not really looking to sell it (I've only owned it for a matter of hours) but it is somewhat interesting. What would be the value of a lathe with 24' of center distance, if in good condition?
In spite of that offer, I'm going to tear into it and see what shape it really is in.
alskdjfhq:
Hendeyman
