Results 1 to 5 of 5
    rmw
    rmw is offline Cast Iron
    May 2007
    Northeast Atlanta, GA
    321
    Default Need original info on a Hendey lathe
    I am looking for any original info I can find on Hendey Lathe serial # 38293 H1316.
    Greg
    hendeyman is offline Hot Rolled
    Nov 2005
    elfrida arizona usa
    969
    rmw:
    After a detailed search of the records, I haven't been able to find any information regarding Hendey lathe #38293H1316 other than it was scheduled for completion during the last week of October 1952. All of the serial number information for numbers 38290 through 38299 are available,
    except 38293. Sometimes the number is cancelled and then reassigned at a later time, with that in mind, I searched from a thousand numbers
    before 38293 through the end of production in 1954. No luck. I suspect a misfile and it will require more time to find the information you requested,
    sorry for the delay.
    Hendeyman
    rmw
    May 2007
    321
    Thank you, Hendeyman. It has hard ways, 18 speed, 16-1000. 220/440. So I was thinking this was probably one of their latest ones. I understand how they moved serial numbers - just wanted to be pretty sure of its age.
    Greg
    johnoder's Avatar
    johnoder is online now Diamond
    Jul 2004
    Houston, TX USA
    18,458
    Quote Originally Posted by rmw View Post
    Greg
    Manual scan for 12 and 18 speed. Thanks to Greg Menke for hosting:
    http://pounceatron.dreamhosters.com/...dey-Op-Man.pdf
    rmw
    May 2007
    321
    Thanks, John.
