Okay, on my other recent thread on under lathe storage, I was asked by a couple of people for more information on the screw machine. Here we go.
This machine was described by Rose in his 1888 Modern Machine Shop Practice. The version shown in his book is very similar to mine except for the base and for a couple of shields on the stock feed mechanism. One of the illustrations was useful to me in replacing a couple of missing small parts in the stock feed system.
When I got the machine, the headstock bearings were badly grooved as was the spindle. I turned the spindle down to clean up the bearing surfaces and repoured the babbit bearings. I got a reasonably good pour on about the third try. I then bored the bearings out with a makeshift rig and hand scraped them to align the shaft with the turret. I cleaned everything else up and made some tool holders for the turret out of old electric drill chucks.
First, here is an overall view of the machine and its motive power. The lathe is powered by a DC motor with variable speed control system. The system operation is very simple. An off/on switch, a rheostat speed control knob, and a reversing switch. Turn on the power, select forward or reverse, and dial the speed to what you want. Beyond that, I know nothing except that Pratt & Whitney did not supply it. A previous owner had rigged up the system, then used heck out of the machine with it. My fond hope is that it will continue to function without my having to learn to fix it. Looking at the machine itself, you can see three levers in the picture. The one furthest to the left feeds stock when pulled to the right and closes the collet chuck when pushed to the left. The small one on the cross slide moves tools crosswise as appropriate and has adjustable stops to limit travel. The one on the right rotates the required cutter into position and feeds the turret forward into the work, then out after the operation is completed. Of course, the name hand screw machine tells you what moves the levers.
The second photo is from the turret end and shows the turret with its six tool positions and the six stops which can be individually set to properly limit the tool motion for each tool.
In the next photo I am drilling the mounting hole in the end of a knob
Next you see tapping the hole. This is a simple tap holder mounted on a shaft which is free to slide in the tool holder. Since this is just a 6-32 tap, I just grab on to the rubber coated body and hang on until the tap bottoms. At that point I reverse the lathe and hold the chuck while the tap unscrews. Done.
Next, shaping the side of the knob with a form tool in the front tool holder on the cross slide.
Finally, cutting off and shaping the end of the knob with a form tool.
And, the knob ready for final polishing
When I made the “production batch,” the knobs took about 45 seconds apiece to make. Finding all the knobs in the shavings added a bit of time, also. Polishing was done as a separate operation with the knobs screwed onto the end of a screw held in a drill chuck mounted in the collet.
