Home Page Forums Articles Videos Search Register Advertise
Go Back   Practical Machinist - Largest Manufacturing Technology Forum on the Web > Open Discussion > Antique Machinery and History
Antique Machinery and History Discuss antique machinery and the history of machine types and their manufacturers
Reply
LinkBack Thread Tools Display Modes
  #1 (permalink)
Old 12-05-2009, 12:01 PM
Default renovating an old WW lathe
here's one way to do it:
http://cgi.ebay.com/Old-Watch-Jewelr...item23042cca0d
or just search eBay for "Peerless lathe". Item #150393899533
headstock replaced by some sort of piston. LOL
I own a book I purchased years ago from Lindsay I think. Explains how to build a vertical mill from mill stock (mostly). I think it was called the Ramah mill. He had you slicing a truck piston across it's width, then drilling the hole for the spindle (or maybe that came first), filing everything nice and flush, then bolting it back together, or some nonsense. But the dude on eBay bypassed most of that. It seems.
Something tells me this is a popular way of replacing a headstock. In some regions anyhoo.
  #2 (permalink)
Old 12-05-2009, 12:25 PM
Quibble: A Peerless is not a WW type lathe.
I too saw that thing and was amazed. At least the Borel base is worth $25, so the starting price + s&h is OK. Marshall (Peerless) serial numbered their headstock, tailstock and bed because they were hand fitted and not able to mix and match. Thus a Peerless bed and tailstock are not much use without the matching headstock.
And to complete the story, American Watch Tool Co. Webster-Whitcomb (the real WW) lathes only have a serial number on the headstock because you can mix and match the headstock, tailstock and bed.
Larry
  #3 (permalink)
Old 12-05-2009, 12:32 PM
rivett608's Avatar
Hey... it may be worth the price for the entertainment value of the thing?
I think in the that old Popular Mechanics book about building your own power tools there was one that used pistons......
  #4 (permalink)
Old 12-05-2009, 01:51 PM
That brought back memories - I once saw a 10" ish polisher - wirebrush - grinder in an old blacksmiths shop that used old CI pistons as bearings with built in support, 3HP motor.
Apparently it had run over 15years on the original pistons.
''oh yeah'' said a sceptical and green Sami,..the old timer tapped the side of his nose and took the cover off one of the pistons.
The inside was filled with cotton waste and oil,....... as near as no play in the bearings either - red face time
That old timer knew a thing or two,.......... strapped for cash after the war, he'd used his skill and knowledge......... though he had the grace to admit that when he built it, he told himself ''it would do until something better turned up''
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.3.2
Ad Management plugin by RedTyger
