Sawmaster power hacksaw - do they all buck like this?
Community On The Web
Results 1 to 16 of 16
    crrmeyer is offline Hot Rolled
    Nov 2006
    Southern California
    734
    Default Sawmaster power hacksaw - do they all buck like this?
    I recently ran into a Miller Knuth 3167 Sawmaster power hacksaw. It must be an early one as it does not have the power switch positioned to turn off at the end of a cut. The power switch is mounted to the front leg casting under the vise handle.
    After a bit of cleanup I installed a new Starrett 14x1 10tpi hack saw blade and tried cutting a piece of 1" angle iron. The saw cuts well but bucks upward as it relieves the spring pressure at the end of each cutting stroke. Now the Sawmaster is a bit different than other power hacksaws as it spring loads the hacksaw down on the cutting stroke and relieves some of the spring load with cam action on the back stroke. It does not actually lift the blade on the back stroke. Is this normal?
    Also, an thoughts on oil should I used? The on-line manual is not specific regarding viscosity (such as would 30 weight non-detergent work?) But in certain areas they do want an oil with adhesives.
    Feb 2004
    Metuchen, NJ, USA
    4,828
    Crrmyer:
    1) Thank you for posting nice photos of an interesting machine.
    2) A 10 tpi blade might be a little bit too coarse for 1" angle, depending on whether it is light or heavy gauge angle. You should have minimum three or better yet four teeth fully within the thickness of the steel. You might be seeing an effect of the teeth catching in the work.
    Try finer-pitch blades and see what happens.
    3) I've had no luck with auto engine oils, including non-detergent oils, on machines that have wool felt oil wicks. It somehow clogs up the wicks.
    An "oil with adhesives" sounds like Way Oil to me, but that's more of a guess than anything. I would presume this is on the sliding surfaces?
    I hope others who know more about lubrication science chime in on this. We have at least one lubrication professional on PM. I hope he sees this.
    JRR
    peter is offline Titanium
    Mar 2001
    New England
    2,793
    Many of the ones I have seen were either bolted to the floor or mounted on a hvy skid with rubber pads to prevent the saw from walking across the floor.
    I assume you can reduce the spring tension to match the load. Is there a hand wheel for that? Should be.
    Being a home hack I have no idea about proper lubrication. I got a deal on a 5 gallon can of 30wt non detergent and I use that for everything. When I finish this can, I think I will have a collectors item.
    Limy Sami is offline Diamond
    Jan 2007
    Norfolk, UK
    12,934
    Is the motor going round the right way?.......... don't laugh it can make a lot of difference on some of the more, shall we say, basic power hacksaws.
    Mar 2001
    New England
    2,793
    Limy, That makes me think, maybe it would help to slow it down.
    Nov 2006
    Southern California
    734
    Thanks for the replies. I did verify that the motor is turning the correct direction (counter clockwise when facing the open drive gear). But, on closer observation the previous owner must have been running it with the pitman arm not bolted to the large gear securely, since the original threaded how is stripped out. There are other threaded holes adjacent to this hole (before and after) but in either position there still seems to be the bucking. The previous owner also replaced the pitman arm with a much nicer designed home made one with an extra degree of freedom to minimize any alignment issues.
    Lowering or raising the tension on the spring did not seem to make much difference. I did
    have to put more tension on the included V belt than I would like to keep from slipping at the start of a cut. (per the manual I start with the blade not resting on the material).
    Sounds like possible improvements are:
    1) Use a 14 tpi blade (which is what the manual calls out for general use). Victor Machinery Exchange is one of the few places that has 14tpi and they are pretty cheap, but the brand is unknown (see link below).
    2) Slow it down with a smaller motor pulley.
    3 ) Change the motor to allow for variable speed. I could put a variable speed 1/3hp DC motor on it out of the junk pile. Or maybe that odd dual speed (1725/1140rpm) 1/3hp single phase motor I have had laying around.
    4) Replace the V belt
    5) Helicoil the original pitman arm mounting point on the big gear and see if the bucking in a spring tension lift-off timing issue.
    I'll probably start with 1,2, & 4.
    The Sawmaster is a 2x bigger and beefier hacksaw compared to the Craftsman/Cove/Atlas hacksaw I have used in the past. It would be interesting to see if for general once-off use which is more effective and easy to use. I like the handle on the front of the Sawmaster to engage the bigger blade, but the Craftsman has positive liftoff of the blade on the backstroke.
    Thanks for the input.
    Link to blades:
    Power Hacksaw Blades - High Speed Steel - 12 to 24 inch long.
    Garwood is offline Titanium
    Oct 2009
    Portland, Oregon
    2,280
    That's a unique saw. I've been using a #6 Marvel for a little while now, long enough to get the hang of what it does effectively and what it's limitations are. While the saw I have is quite a bit larger it doesn't buck, vibrate or walk anywhere even with a full capacity cut in high gear where the moving components become a blurr. Coarse tooth blades in the thinest material haven't been a problem. I've cut 10 gauge steel with a 6 tpi blade. The cut was pretty good, no bucking or unusual issues, I was surprised it was as smooth under such use.
    I use vactra 2 on the ways/pivots and DTE heavy medium in the bearings.
    RickWG is offline Cast Iron
    Jul 2007
    So Cal
    387
    What is that vertical handle at the back? Mine doesn't have that....
    Jan 2007
    Norfolk, UK
    12,934
    Quote Originally Posted by crrmeyer View Post
    I think you've answered a lot of your own problems there, ..........as I read that, the timing of the crank pin has been altered which effects the geometry of the whole motion, how is the lift off cam driven?......and off which shaft?....... if a seperate shaft from th main crank it could be timed wrong.
    I'm not harping on, but is the motor rotation as per manual?
    I'd check up on stroke rates before altering the speed.
    k3vyl is offline Hot Rolled
    Feb 2008
    newark DE USA
    828
    the gizmo with the handwheel sticking up at the back end looks a lot like the feed adjuster on a marvel drawcut saw.If the manual that is available for your saw is not too great,you may get some insight from looking at some marvel manuals.
  11. #11
    Nov 2006
    Southern California
    734
    k3vyl - the gizmo with the handwheel sticking up at the back end is the tension spring adjustment for the downward cutting force.
    Limy Sami - I checked the motor rotation, it is the correct direction per the manual. I also unloaded the tension spring (effectively eliminating the downward spring force and making any timing issue of the cam moot). It still behaves the same.
    RickWG - The vertical handle in the back is to pull the saw with (works better when there are wheels on the saw). Mine has part of the handle broken.
    Garwood: I am envious of your marvel being able to cut light weight stuff. This one really cuts, but the downward force is large enough that it really wants to cut big stuff. For fun I put a piece of .093 x 2" aluminum on it and the saw cut half way thru before bending the aluminum in half. It makes me wonder if I should be adding a compression spring to reduce the downward force. I'll have to get a scale and measure the minimum downward force.
  12. #12
    Oct 2009
    Portland, Oregon
    2,280
    The only hacksaw experience I have is with the old Marvel #6 I have. It uses two inputs on the feed leadscrew to achieve good cutting- An adjustable cork friction clutch that is only really necessary to increase past zero if you want to power through thick/hard materials with a blade life sacrifice and an adjustable positive downfeed system adjustable from .003" per stroke to .036" per stroke. The blade is lifted a fixed 1/8" on the backstroke, independant of feed. Most cutting I do is 1/2" through 4" mild steel at 80 strokes/minute with .012" downfeed/stroke and just enough tension from the friction clutch to take up any freespace between the blade and the work quickly.
    If your saw doesn't have a means to positively limit downfeed I can't see it working very effectively on thinner materials regardless of blade tooth size. Are you certain the saw has no type of friction feed or downfeed limiting system that isn't working properly (I have no experience with saws like yours)
  13. #13
    Nov 2006
    Southern California
    734
    Quote Originally Posted by Garwood View Post
    No, this saw has no type of friction feed or downfeed limiting system. It really wants to cut thicker/beefier stuff. Most of the smaller hacksaws I have seen have gravity loading of the teeth with no fixed feed. I would not mind finding a smaller sized hacksaw with positive downward feed. But the Marvel #6 at 1400 pounds is a bit more than I need (the Sawmaster is about 225 lbs).
    I wonder what smaller sized power hacksaws exist with positive or friction feed?
    I think a compression spring or gas strut to counteract the downward force (about 35 lbs on the blade at the minimum spring tension) for thinner material may be a simple solution. Or maybe just an adjustable hydraulic dashpot as seen on most horizontal bandsaws (like old Kalamazoo's) might work.
  14. #14
    Mar 2001
    New England
    2,793
    You can always put light stock in a vise and use a hand saw or a sawzall. You really appreciate these heavy floor models on stuff like 2 inch bar stock.
    The best tool for medium and light cutting are the small ban saws. In fact most home shops use the little 6 inch band saws. They are ideal for your needs. Perfect really.
    Here is a link to what I mean. I DEFINITELY do not endorse this brand (not one way or other). FYI, this is the right type of tool for your job:
    Horizontal/Vertical Metal Cutting Bandsaw
  15. #15
    Nov 2006
    Southern California
    734
    peter - I agree, these saws are optimal for cutting thick stock.
    After thinking about it last night, 35 lbs. of force on the blade seemed a bit excessive. So I rigged a tension spring to the end of the saw to counteract the weight and for fun tried cutting the same piece of thin aluminum with 7 pounds of cutting force. It cut the aluminum with no problem, though not quite as fast as with the higher cutting force. It also did not buck nearly as much.
  16. #16
    Paul E is offline Aluminum
    Jun 2006
    NM
    50
    Smile saw bucks
    You may have addressed this but I didn't see which way you put the blade in. My marvel# 2 is definitely a drag saw and will jump off the floor if used the wrong way
