Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    gregg-k is offline Cast Iron
    Apr 2007
    Ottawa, Canada
    338
    Default Who makes this Drill Sharpening Jig ?
    I got this drill sharpening jig a while back, and set it up with its own motor this week. I think I've seen an ad for this jig in a 1939 Atlas machinery catalog as a "Model W30" ... but nothing more.
    It's much more rigid and stable than the gool old General jig, and the micrometer adjustment makes it easier to make the drill lips symmetrical. Capacity is up to 1/2" drills.
    However, I've had to make and educated guess about how to set it up, and I'd appreciate if one of you could point me at some info about using it properly.
    Many thanks,
    .. Gregg
    Mebfab is online now Diamond
    Jun 2003
    Mebane North Carolina USA
    4,242
    Good question. I have 3-4 of them myself.
    Clive603 is offline Stainless
    Aug 2008
    Sussex, England
    1,709
    Ha! Second time this beast has come up recently.
    Its a Delta 1296 Drill grinder attachment.
    Look back to the Mystery Tool thread started by Steve S on 23 rd August for a bit of discussion and a link to where an instruction manual can be found.
    Bit more complex than the intent of Gordons DIY thread but a shop made version would make a nice project as well as being a bit more predictable than the General / Picador et upteen clones style. Although they can work very well provided you don't get the instructions mixed for the two different varieties.
    Clive
    atomarc is offline Stainless
    Mar 2009
    Eureka, CA
    1,216
    Gregg,
    I too have one of those...plus ALL the manuals on how to set it up and use it. I actually have two manuals as two different companies made similar grinders.
    One was made by Delta Power Tools (Rockwell) and it is the #1296 Drill Grinding Attachment. The second one was made by Atlas (the same folks who made the lathe) and it is a #2915 Drill Grinding Attachment.
    Yours is the same unit I have, it's the Atlas model. If you give me a few days and a shipping address I could probably copy the operating instructions and send them to you.
    EDIT. I just read Clive's Post. The two grinders are similar but on close inspection are not the same. The picture you posted is the Atlas, not the Delta.
    Stuart
    Apr 2007
    Ottawa, Canada
    338
    Thanks for the speedy replies, Guys!
    Interesting that both Delta and Atlas sold jigs that were so similar. Clive, I downloaded the Delta instructions you pointed me at; thank you!
    Stuart, if you have the instructions for the actual Atlas W30 jig I have, I'd appreciate a scan of it. I'll PM you with my contact info.
    Thanks again,
    .. Gregg
    Apr 2007
    Ottawa, Canada
    338
    Default My head hurts!
    I went through the Delta instructions, and it sure could use clarifying and editing ... talk about hard to understand!
    From what I could tell, it looks like the Delta jig grinds against the drill against the circumference of the wheel, while the Atlas grinds against the flat side.
    Not sure if any of the instructons of one maker's jig apply to the other, but what I'm trying to figure out for my Atlas jig are:
    1. the distance the drill must extend from its holding shoe, and
    2. what starting orientation the drill's lip must have to the wheel
    Thanks again,
    ... Gregg
    Lew Hartswick is offline Hot Rolled
    Dec 2003
    Albuquerque, NM USA
    566
    We have one of the Atlas at school. I really like it. Just wish it would handle S&D bits.
    ...lew...
    USMCPOP is offline Titanium
    Jul 2005
    Midlothian, Virginia
    2,587
    Here's an old 1943 Atlas catalog FWIW. The attachment is toward the back.
    http://www.notforsale.net/old_iron/p...atalog-D43.pdf
    Apr 2007
    Ottawa, Canada
    338
    Default Completed!
    With *many* thanks to the information I got from atomarc and clive603, I was able to properly set up my drill sharpener. Lots of quality time spent this weekend reclaiming many old drills !
    I now know that it is an Atlas model W30, or the model 2915 as it became known later on. From the manual that automarc sent me, I discovered that the jig originally came with a set-up fixture, which I was missing. However, I was able to do without it because the manual also gave the key dimensions for set up ... the fixture is really only to make the set up process idiot proof.
    Another neat feature is that the jig can be set up to true the wheel prior to sharpening a drill.
    I discovered also that there is no such thing as a universal overhang for putting a drill in the holding "chuck" ... in fact, its the drill's orientation that's critical to getting the cutter geometry correct. A bit of practice, and I got it right every time.
    It's nice to have a dedicated machine, with a true stone that's ready to use at any time!
    ... Gregg
    FTF Engineering is offline Hot Rolled
    Oct 2003
    Philadelphia, PA
    692
    Quote Originally Posted by gregg-k View Post
    I have one of the cheapie General fixtures and it's finicky as well. If I remember the geometry correctly, the reason for the issue is the angle of the flute helix. You see... The rate of spiral in the flutes usually changes as the diameter of the bit changes. In other words, smaller drill bits usually have a tighter flute helix than larger drill bits, and since those fixtures register the drill's position using a stop on the flute, smaller bits will rotate more by the time you get to the grinding surface, and larger bits will rotate less. This affects where the web is when it contacts the wheel.
    In reality, you don't really care at all about the distance from the wheel... What you really want to control the amount of rotation from the registration pin to the grinding surface. Unfortunately, you can't move the registration pin, so the only thing you can do is adjust the distance from the wheel.
    All that said... I'd still rather have your fixture than my General.
  11. #11
    spope14 is offline Stainless
    Jan 2004
    Claremont, NH
    1,577
    WOW, I have the exact same jog fixture at my school shop in a box, all but for the motor and wheel set-up. I may have to find a way to hook it up to an old tool grinder I have.
    Great, Thanks!
  12. #12
    Lionel Charron is offline Plastic
    Sep 2006
    Winnipeg, Manitoba, Canada
    Quote Originally Posted by atomarc View Post
    Gregg,
    Stuart
    Atomarc,
    I need a copy of the manual for the W30/2915. Could you send me one either electronically or snail mail?
    I will gladly pay you for it. Please send me a private message if you can
    Lionel
  13. #13
    Mar 2009
    Eureka, CA
    1,216
    Lionel,
    I DID send you a private message........last week! Do you know how to access it?
    Stuart
  14. #14
    ballen is offline Plastic
    Garbsen, Germany
    Default Instructions for Atlas 2915 / W30 drill grinder
    Hi Group,
    I've recently been given an Atlas 2915 / W30 drill-grinding jig as a gift. Could someone please post the instructions on a web page for me, or email me a copy?
    Thanks!
    Bruce
  15. #15
    Apr 2007
    Ottawa, Canada
    338
    Quote Originally Posted by ballen View Post
    Hi Group,
    Thanks!
    Bruce
    Hi Bruce,
    I tried posting the manual to Photobucket, but they do not accept a pdf file. So, PM me your email address, and I will send you a copy of the manual for the 2915.
    .. Gregg
  16. #16
    bruto is offline Stainless
    Mar 2008
    Benson, Vermont
    1,024
    Hi Bruce,
    .. Gregg
    Try box.net. You can get a free account and share files from there.
  17. #17
    Regal13's Avatar
    Regal13 is offline Cast Iron
    Feb 2008
    Richmond, KY
    384
    Where can you get a grinding wheel like that one?
  18. #18
    Apr 2007
    Ottawa, Canada
    338
    Quote Originally Posted by Regal13 View Post
    I got that particular one from a friend who'd had it for years and no longer used it. No name on it, sorry.
    I have another wheel like it, only a lot smaller. It is a synthetic ruby wheel that was made by the old Black & Decker company for Sioux valve grinders.
    Both wheels are unique in that they are made to be used on their side face.
    I would imagine McMaster Carr among others would have similar wheels ... try Norton abrasives as a brand name.
    ... Gregg
  19. #19
    Riderusty is offline Hot Rolled
    Jan 2002
    Sea Cliff, NY & Portland, OR USA
    540
    Interresting, I hadn't seen this thread earlier. This summer I found a similar if not identical drill jig at a garage sale but it is lettered Millers Falls #7080. Wasn't sure about the set up but gregg-k's pic cleared that up. Thanks.
    Tom B.
  20. #20
    Dan Craig is offline Cast Iron
    Aug 2006
    Orange County, CA
    254
    Anyone have one of these for sale and what sort of $ are you looking to get for it?
    I'm in Southern California so shipping could be a factor unless you're within driving distance.
    Dan
