Bore.Stroke.Port
- Jul 26, 2014
- Brooklyn, NY. USA
Hey guys,
I bought a 80's Series 1 J head Bridgeport Textron that appears to be mint. The table surface, knee (chrome), column, and saddle (chrome) have all the scrape marks. It doesn't seem to have any scars (drill holes, end mill slots, scratches, etc). Minor paint chips, and has dry oil residue. The owner said that he bought 5 new BP mills and this one got used maybe 20 times since it was purchased.
Table Question:
I've used several BP mills, different vintages and models. On most of them I've noticed that the dovetails on the underside of the table have scrape marks. Some are more noticeable than others, depending on the wear, but they are usually always noticeable at the ends of the table. The 80's BP I bought, doesn't seem to have any at all, and the dovetails appear to be ground. I can not find any scrape marks, even on the ends of the table. Did Bridgeport ever grind these dovetails and not scrape them? I do not believe they are worn, I could be wrong, since there is no visible wear, gouging, scoring, etc.
J head question:
I would like to swap out the step pulley drive to a variable speed 2J (not interested in VFD). Can you fit a 2J variable speed assembly on a J head quill casting/housing?. I looked at the part numbers and compared them, and they all seem to be the same. I've read that the spindle length may vary, aside from this, any other things that do not allow for this swap? I know that I can just buy a complete 2J head and just swap out the heads, but I want to know if its possible to just swap out the drives.
Thanks in advance.
I'll post pictures of the mill soon.
Table Question:
J head question:
Thanks in advance.
