Advice needed - DSM speed indicator fix?
Results 1 to 5 of 5
    Jul 2006
    rochester, ny
    1,694
    329
    458
    Default Advice needed - DSM speed indicator fix?
    The speed indicator has never worked in my DSM-59 (bought used a few years ago). Took a closer look, seems like the indicator tip is stuck in the support tube of the control box. Wondering the best way to get it apart and sliding?
    I tried removing the control box from the support tube, couldn't budge it. Same for removing the tube from the headstock. Thinking they might be rusted stuck from years of coolant. Kroil? Gentle heat?
    Apr 2005
    Michigan
    300
    1061
    51
    Did you check to see if the lower end of the indicator rod is connected to the frame that holds the intermediate pulleys?
    Also..., when taking anything Hardinge apart, always look for a second set screw under the first.
    Jul 2006
    rochester, ny
    1,694
    329
    458
    Thanks for the double set screw tip, I'll bet that's exactly why they wouldn't budge.
    The lower end is connected, and bent and buckled.
  4. Likes Stradbash liked this post
    Apr 2005
    Michigan
    300
    1061
    51
    The support tube goes into the headstock 2.75” and a fair bit more than that into the control box. Mine sat in unheated storage for a few years in a damp climate and I didn’t have much trouble getting apart.
    If it were mine though I’d start by disconnecting the lower end of the indicator and seeing if I could pull it out. You’ll have to be a bit of a contortionist to do that though... Advice needed - DSM speed indicator fix?
    Jul 2006
    rochester, ny
    1,694
    329
    458
    All fixed! I wasn't able to pull it out from below, but once I got the box off, a few taps on the indicator rip did the trick. Straightened out and cleaned the wire and all is well.
    Thanks again Stradbash!
  7. Likes Stradbash liked this post
