zimbo
- Apr 22, 2017
- Richmond, VA
Hi there.
I have an Adock Shipley Bridge Port vertical mill I acquired recently and the electrics are in a shocking mess. The auto feeds have been disconnected in the main DB as well as at the motors on the X & Y. knobs and switches missing there too. I haven't found a wiring schematic for it and am watching how Marc UK is doing on his before I tackle this.
The drum switch is broken on the on position and one of the 4amp fuses keeps blowing, twice now after a few minutes on.
My thoughts are to scrap all the electrics and bring it into 2018 by installing new contactors and overloads to make it work as a manual machine 1st and then when I get time, will strip and clean the original X&Y motors.
Not even sure if the brown box, think its a transformer is working as well. The forward and reverse switch is working 100%.
So my questions are...
1) Do I do as above or keep the original contactors and find out what the issue is?
2) What are the small ceramic fuses protecting? They are 4 & 16 amps.
3) If I start from new with all new switch gear I assume its as simple as wiring a regular 3 phase motor? Does each direction have its own contactor and overload?
Would like to hear your guy's thoughts.
Included some pics. Sorry they are landscape view. Upload seems to change from portrait view.
