The 2 lube lines to my Bridgeport mill screws bracket have a transition to a larger tube rather than using the 5/32" tube with brass insert. The larger tubes seem to be close to the same outside diameter as the hole in the bracket. Anyone see any problem with this setup or should I revert to the smaller tube and brass insert?
