Any thoughts on how to go about repairing this pedestal?
Results 1 to 10 of 10
    Sep 2016
    83
    7
    10
    Default Any thoughts on how to go about repairing this pedestal?
    This was one of the casualties of a stuck knee gib. Still working on unsticking the knee but now that I have the pedestal out I can see it is going to need some work.
    Not having a mill while working on a mill limits what I can do.
    Bigger picture:
    Jan 2002
    West Coast, USA
    7,350
    326
    3990
    Seems you could do the repair with just your lathe. Cut off the broken top of the pedestal and line bore a stepped area to receive a new top. Remake the top part with a matching stepped section to match the receiver you've bored into the pedestal. Epoxy or braze back together. It's pretty much in compression anyway.
  3. Likes Newman109, DrHook, timvercoe liked this post
    Sep 2016
    83
    7
    10
    I do have a lathe and a surface grinder. So that is actually an idea.
    May 2003
    Iowa
    9,590
    2794
    3443
    1. don't worry about thte pedestal until you unstick the knee.
    2. new from H&W they are just over $200.
    3. look for a used one on ebone
    JR
  6. Likes DrHook liked this post
  7. #5
    Mar 2009
    3,692
    72
    595
    Quote Originally Posted by SirRage View Post
    Bigger picture:
    The part that has that chip is part of a ring with those 3 tapped holes. The ring is about 1/4" thick. Then below the ring the wall of the tube is thinner. I would cut down the entire ring section and turn a new ring with a step probably at least 1/4" long. Then you could tack weld the new ring in place and grind the welds down to be flush with the cylinder body. Finish off with body filler, there is no shame in using filler it because a Bridgeport is covered all over with it.
  8. #6
    Aug 2008
    Sussex, England
    3,027
    9
    585
    As you can get in from underneath drill out the damaged holes to take a "curved T" headed insert with the stem tapped to take the securing screw. Anoint with suitable glue and push in from underneath then build up the surrounding area with hard filler. Devon or similar metal loaded probably best. J-B weld would work OK if you dammed things so it can't escape whilst setting. Time I did similar fix I just used ordinary body-filler and called it good as there was solid metal, as in this case, bolted on top.
    I'd be unsurprised to find that drilling out, filling with Devcon and fitting a helicoil or merely tapping would male a perfectly satisfactory fix. Despite having successfully tapped holes in Devcon it needs a braver, or at least one with better understanding of the strength of metal loaded fillers, than I to try it there tho'.
    Clive
  9. #7
    Sep 2016
    83
    7
    10
    Ok, got a used one for a little over $100, going to clean it up when it gets in and hopefully, the knee will be unstuck by then.
  10. #8
    Jun 2012
    Michigan
    8,088
    2343
    2608
    I was going to say with not even one machine you could flat file the top to square and smooth in the still good places/
    Drill and tap three new hole in good places.. fill the empty places with any filler and file smooth to hide and put it back in place. Still plenty strong and would look like new.
    but done is done for $100 is good.
  11. Likes Richard King, awake liked this post
  12. #9
    Jul 2005
    Cottage Grove, MN 55016
    5,744
    3109
    3397
    Why not file off the burrs and turn the nut and line up the holes in a good spot,transfer punch and drill & tap some new holes. Also The stuck gig is not new to the forum.
    knee stuck - gib is jammed
  13. Likes michiganbuck liked this post
  14. #10
    Jun 2012
    Michigan
    8,088
    2343
    2608
    And the broken area looks like only a few threads were in use and perhaps so dry they became stuck over time..unsticking may have been resolved with drilling out or soaking but would have been best served with a bit of grease or never seize at the original long past assembly.
    Agree most machines were put together with not expecting them to set out in the weather so becoming one solid mass over many years.
    I
