Adding to my queries from "head swapping" thread earlier today...
The newer J head (1.5hp motor) has a bizarro issue with the step pulleys. I ran the head to check it was ok before attempting to mount it on the older machine. Three of the four speed settings run fine but on the third pulley set down (speeds 420/3500 according to the speed info plate)the v belt is so loose its barely touching the pulleys.
I assumed the four steps are one unit machined from one lump of Aluminium, is this not the case?
Can I take the pulleys from the older head(1hp motor) and swap them or are they different sizes?
Thanks, Matt.
Thanks, Matt.
