I have A Bridgeport jhead 1 hp with the vram, and I'm a hobbyist. Finally got the nerve to rebuild the head after reading a book, and finding the fine feed quit working. I have stripped the head down to the casing. 2 questions 1 the quill housing initially moved easy enough and I used a copper bar to tap it out from top down - (spindle bearings and quill removed) casing is now stuck just below the fine feed nut opening where I took the setscree out. What happened? 2. My motor works fine - but is covered with black gunk - will cleaning it be worthwhile. Thanks for any response
