Hey all,
So I'm trying to get an old series II special up and functioning. When I got it, the powerfeed was pretty much smoked. Being new to this stuff, I sent it back to a contact I had to refurbish, who decided it wasn't worth doing and sent me an import one for super cheap and kept the thing for parts.
As I've learned more, it's clearly not an easy swap/replacement for the series II specials and i'm in a bit of a pickle now. My machine had the 8F powerfeed on it. Replacement cost is very high... I know servo makes a kit with the feed but it's also around 1300$ from MSC. My budget is super tight and I can't quite afford that right now.
So my question to you all mainly is, Do you know if a 6F powerfeed would work on the series II special mills? My machine has the 11x58" bed on it, so it's rather massive. The guy that i sent my feed to, apparently doesn't have it anymore, so i can't even get the housing back to just run it manually, so i'm sorta screwed at the moment. He has a 6F that's working, but i'm trying to figure out if it'll work and haven't been able to find much information on it.
The other option, is to try and make and adapter to make this import feed work. I have the end of a series 1 table screw, that i think i could cut off and adapt to the screw on my machine, and could potentially get this import to work, but i'm concerned it will wear the the motor out and smoke it even if i do get it going.
I won't be using the powerfeed much at all, mainly just looking for the easiest way to get the table under manual controls again so I can use the mill.
Any help is much appreciated!
Matt
Matt
