Bridgeport J (step) head motor upgrade?
gsondubs
Oct 19, 2016
USA
Hello everyone
I'm new to machining, purchased an older BP J step head w/1 hp motor. I have been doing research to see if it is possible to install a 2 hp motor onto it. I've that I will need to look for a C face motor, an adopter plate, extend the shaft and bore out the step pully.
I want to see if anyone had done this and if you have any pictures to share? I am very curious on what Motor I need for this conversion. Model number?
(I do have 3ph power)
Thanks in advance
It's possible but why. Just to have more horsepower. When you start taking real heavy cuts on a BP model like yours the whole thing will shake and vibrate unless you have it bolted to the floor.
No offense gsondubs, but I have seen it happen. You are fortunate if you have real 3 phase power available.
only "upgrade motor" i coudl see being usefull would be a 3500rpm motor if you mostly ran sub 1/2 inch mills and or carbide. i didnt know they came like this right from BP. as luck woudl have it i got one not knowing and so glad i did. i do mostly knife work and other small things and find the extra speed nice. i think if you have the 1700rpm motor you can still over drive it with a VFD to cheat more rpms
I have old J head step pulley 1hp pancake motor mill. Had it mill scraped and refurbished about 12 to 15 years ago. I have never yet ran out of HP on it or came close to. I run it on buzz box to get 3phase. so I really only have about 7/8hp if that.. You will be fine with what you have.
I also have 2hp variable speed Bridgeport that had refurbished about 10 years ago. When it comes time to sell one I will be keeping the step pulley machine. It is my favorite out of the two.
