Bellaru433
- Jun 8, 2017
I have a Bridgeport M head that takes a Morse 2 taper and I am wondering how I would go about Installing a keyless drill chuck..
Where I have to remove the arbor from the Chuck and find a Morse #2 arbor that’s threaded in the same way that the collets arbor that’s threaded in the same way that the collects are and install it in the spindle that way ..Which incidentally I’m having a hard time finding a Morse 2 taper Arbor that doesn’t have a tag on it and is threaded to screw to the spindle,,, or do I just install a let’s say half inch diameter straight shank on the chuck and just install a half inch collet And then install the chuck into that... i’m new to all this and need some help .. i’m not even quite sure how to remove the arbor out of the Albrecht keyless chuck,,I’m thinking I’ll be able to unscrew it and screw in whatever I decide to change it to ..????
