Bridgeport Ram swap compatability
evesdropper
Nov 26, 2009
Omaha, USA
I have a 1964 Bridgeport with dovetailed ram and a M head (MT2 spindle). I purchased a Bridgeport of unknown age (serial number was unreadable due to rust) with a working 2j2 head but most everything else on that mill is broken or work right out.
Can I just crank off the ram with the 2j2 head and replace the ram on my current mill?
Or should I swap the heads only?
Any advice is appreciated. Thanks.
Both Rams should be the same. Turrets should also be the same.
You can't just swap heads becauswe the M head mounts different than the J/2J.
You could also change from the "nod" pivot out.
JR
