Twistedfab13
- Jul 31, 2017
I just picked up 12” Bridgeport Rotary Table and it looked great on the outside but wasn’t moving well. So I started to take it apart and found everything was rusted. No oil was in there. I figured on using evapo-rust for pretty much the whole thing. My question is the roller bearing on the main shaft. Can it be submerged in the evapo-rust. The roller bearing itself isn’t rusty but the shaft above and below is. I don’t really want to remove the bearing. So do you th8nk evapo-rust will hurt the bearing?
