nearbeer
- Jul 29, 2009
- Greenville, SC
Spent some time this morning trying to get the B-Port disassembled; I had an issue several weeks ago where I was turning the Y-axis screw to its lock and when I tried to crank it a bit more so that I could removed the 3/4" nut holding the handle on the shaft, something gave way and I was left with a free spinning screw.
I removed the allen head bolts that secure the side pieces that hold the x-axis screw in place and was able to pull that screw out...
Since the y-axis screw was free spinning and couldn't hold it with one hand while trying to removed the handle nut with the other, I used a short length of pipe to wedge b/w the handle and the ground...worked like a champ...nut broke loose with moderate effort.
I then removed (4) more allen head bolts and the screw slid right out (more like popped out with a slight tug)...no need to twist and twist and twist and twist and...you get the idea...the screw out.
Not sure of what I sheared on the y-axis screw but here is a close up...
Made a bone head mistake of not moving the table to one side in preparation for sliding it off of the knee...so back into the mill goes the screw...
Also, here is what happens when you don't wear gloves while twisting the x-axis screw out...
Anyhoo...pretty successful episode of "This Old Mill" today.
