The oil fill cup just below the speed dial on my Bridgeport Mill (2007) apparently busted off when in the previous owner's possession. All that remained was what looked like a plugged hole. I was finally able to extract the plug or body of what was in there before and found the tapped hole on an angle. See pic below. Is the fill cup at this location different than the one on the right side? The tapped hole is definitely smaller in diameter. Also, is it supposed to be on an angle or is it just sloppy manufacturing?
