Rick_B
Stainless
- Sep 16, 2011
- Winston Salem, NC
I am leaning strongly towards a DRO purchase for a Bridgeport mill. The mill is a Series 1 J head with a 9 X 32 table and X axis power feed. With the power feed the table movement is 16-1/2" in the X direction and 12" in the Y. I know VERY little about DRO's so I thought I'd start a discussion relating to some high level questions and working down into the details. Please don't consider any of the following as factual statements - they simply represent what I think I know today. At a 50,000 foot level:
What a DRO isn't - it is not a CNC type of functionality. It cannot be programmed to perform a series of steps that can be executed by the push of a button.
What a DRO is - in simple terms it is a tool to measure and monitor table movement but the movement is executed by either manually using the the lead screw or a power feeder in one or more axis. In other words a DRO replaces the standard lead screw dials as a means of measuring how far the table has moved in any of one, two or three directions (depending on what you buy). As a result, any lead screw backlash is no longer significant because the DRO is measuring only actual table movement where as the dials are factoring in any backlash in the lead screw/nut configuration as well as table movement.
If the above is correct then let's drop down to 5,000 feet
the DRO uses a scale on each axis to measure movement and reports that back to a display - Question - how does the scale actually measure the movement?
When using a DRO I believe you can set a zero point and then measure from that zero point and return back to the zero point. question - does the zero point represent the tool center - in other words can the tool diameter be reported to the DRO and then it compensates for that diameter or is that an operator calculation?
What can I do with a DRO beyond the elimination of backlash issues. Some examples - touch off the end of a work piece and measure the distance a slot has been cut, touch off the work piece and find its center, touch off a work piece with a hole and find the hole center. Are these typical DRO features? What else can be done with a DRO before you need to consider full blown CNC functionality?
That's probably enough for now - thanks for any thoughts/comments you may have.
Rick
Rick
