alan speyrer
Stainless
- Feb 15, 2009
- Shallowater
While machining parts on my 1978 Hardinge Dsm 59 turret lathe, I had some belt noise. I opened the door to the motor and variable drive system, and noticed the shaft the two pulleys are on had came out of the right side bearing! I looked in the parts diagram, no shaft collars were on the shaft from Hardinge diagram. I think I could move the motor to the right, there are two mounting holes on the motor, that might center the shaft in the bearings better, or I need to machine a collar with a set screw for that end of the shaft. I have run this machine for years and not problems. Any help ?
